C300i C-FD8B ?
  • mrfuser
    • 1626
    C300i C-FD8B ?
    Has anyone run into this code yet C-FD8B ? Says a pinched wire. This is a brand new unit.
    Thanks for any input!
    K
  • Synthohol
    Certified Konica Expert
    • 5905
    Re: C300i C-FD8B ?
    those weird errors id reseat the cpu board and storage board. just a simple remove and reinstall.
    maybe bouncing during transit shifted the board?
    • Synthohol
      • 5905
      Re: C300i C-FD8B ?
      sorry, also, were there any physical upgrades that needed to be electronically installed as well?
      • tsbservice
        Field tech
        • 8064
        Re: C300i C-FD8B ?
        Firstly I would do Self-diag. (Full)
        • mrfuser
          • 1626
          Re: C300i C-FD8B ?
          I took all the wiring off and put back on. I had to do a trouble reset and then unplug the machine, turn power on to take out any residual power and turn power off and plug back in and now it works fine. Sheesh
          • pickle8486
            • Aug 2013
            • 26
            Re: C300i C-FD8B ?
            If I remember correctly. It's loose wiring for the adf. These machines can't handle any bumps.
            Sent from my SM-N986U using Tapatalk
            • strider5555
              • Jun 2008
              • 96
              Re: C300i C-FD8B ?
              Had this today for the second time. Today was a B300i, turned out to be the video cable for the second side scan was not fully plugged in at the baseboard. I'm assuming a setup error when the machine was built. At least it was an easy fix. Previously had that code on a C250i as well. Same issue.
