C224 scan quality
  • copyman
    Owner / Technician
    • Sep 2005
    • 4712
    C224 scan quality
    Has anyone ever seen this (see attached).
    Happens when scanning to computer or copying. Same thing through ADF or off the glass. Printing from computer is fine which rules out consumables.
    This is a NON-E model that has been upgraded to latest version up firmware.
    Thought I solved issue by cleaning optics and doing some adjustments but only lasted about 2 weeks and now back with same issue.
    Only thing I can think of is bad CCD unit or a board?
    Thanks for any help
  • CopierNerd
    • Feb 2015
    • 207
    Re: C224 scan quality
    Thanks for any help
    It seems like the CCD unit is faulty. You can check the second side of scanned image if there is DSDF otherwise the CCD unit needs replacement.
      • 23008
      Interesting moire' pattern.
      What sort of originals are they? Glossy, textured media, laser printed image, light green background?
      If it was a Kyocera I would calibrate the CCD with the special charts. I think I'd do the CCD calibrations on pg G-38 (226) of the service manual. If unsuccessful, I would then change the CCD, and do those same adjustments again. =^..^=
      • Hansoon
        • Sep 2007
        • 3385
        For me first thought would be reseating of the flat cable, than replacing of the CCD unit, yikes
        Hans
        • JacekB
          • Oct 2017
          • 5
          I have the same problem,the device has dualscan and copies from the feeder (2 side) is ok.
          copyman do you remember the solution?
          • copyman
            Owner / Technician
            • Sep 2005
            • 4712
            Sorry for not following up. Customer decided to upgrade instead copier of replacing CCD unit. I wanted to take copier to shop to troubleshoot further but it was at a restaurant with mice & roaches and didn't want to possibly bring them to my shop. My gut feeling is mice had chewed wires but didn't see any evidence of it.
            I would start with replacing the CCD unit and do the necessary calibrations. That was going to be my next move.
            By the way this machine didn't have the dual scan feeder, it had the DF-624
            Good luck
            • Gift
              • Mar 2011
              • 2459
              yummy
              • copyman
                Owner / Technician
                • Sep 2005
                • 4712
                Originally posted by Gift
                yummy
                Ha-ha, many times they offered me lunch and I said I had just ate, on diet, etc.
                To be fair I've seen this in many restaurants. I think they can only control roaches, mice, etc not totally eliminate. My mother was a waitress and would rarely eat out, now I know why.
