BizHub C224e scan to SMB2 network share
  • fsck
    • Nov 2022
    • 3
    I'm having a problem scanning to a network share. As it seems the machine doesn't support SMB2 or newer when connecting to network shares?
    These are versions of FW:
    Code:
    [TABLE="class: data-table-noline"]
    [TR]
    [TD="class: td-indent1"]MFP Card Version[/TD]
    [TD]A5C10Y0-F000-GDF-M1-990[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]MFP Controller BOOT Program[/TD]
    [TD]A5C10Y0-1E00-G00-04(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]MFP Controller Linux Base[/TD]
    [TD]Linux-2.6.26.8-rt16[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]MFP Controller Kernel Program[/TD]
    [TD]A5C10Y0-1C00-GC1-76[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]MFP Controller SubSet[/TD]
    [TD]A5C10Y0-1F00-G00-M6(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]MFP Controller[/TD]
    [TD]A5C10Y0-0100-GDF-M1(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Operation Panel Message Data[/TD]
    [TD]A5C10Y0-8100-GCE-M1-990[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Fax Board Controller1[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Fax Board Controller2[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Fax Board Controller3[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Fax Board Controller4[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Engine Parameter[/TD]
    [TD]A5C10Y0-0054-G00-01[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Engine BOOT[/TD]
    [TD]A5C10Y0-0055-G00-00[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Scanner[/TD]
    [TD]A5C10Y0-0023-G00-33[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Printer[/TD]
    [TD]A5C10Y0-0050-GC2-31[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]ADF[/TD]
    [TD]A3CF0Y0-0024-G00-16[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Finisher[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]RU[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]ZU[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Panel CPU[/TD]
    [TD]A55V0Y0-8900-G60-00[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]DSC1[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]DSC2[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Loadable Device Driver1[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Loadable Device Driver2[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]SD[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Voice Data[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Movie Data[/TD]
    [TD]A5C10Y0-C000-G00-30[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Dictionary Data[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]OCR Library[/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]Panel Sound Data[/TD]
    [TD]A5C10Y0-C200-G00-00[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]MFP Controller Thread Image Parameter[/TD]
    [TD]A5C10Y0-8B10-G00-01[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]MFP Controller PIC Image Parameter[/TD]
    [TD]A5C10Y0-8A10-GC0-06[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]MFP Controller System[/TD]
    [TD]A5C10Y0-1000-GDF-M1(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]MFP Controller Print Controller[/TD]
    [TD]A5C10Y0-3000-GCY-44[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]MFP Controller Print Controller Font[/TD]
    [TD]A5C10Y0-3F00-GCD-40[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]MFP Controller Print Controller Demo Page[/TD]
    [TD]A5C10Y0-3E00-G00-81[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]MFP Controller MIO[/TD]
    [TD]A5C10Y0-5000-G10-W8(00)[/TD]
    [/TR]
    [TR]
    [TD="class: td-indent1"]MFP Controller PIC[/TD]
    [TD]A5C10Y0-8200-GD6-B2[/TD]
    [/TR]
    [/TABLE]
    Do I need a firmware upgrade or any other setting turned on to allow printer SMB2 use with scanning? The only client settings I see for authentication are NTLMv1/v2 and Kerberos. Nothing about SMB1/2/3 with client settings only as server, which doesn't solve anything. Scanner is still unable to send scanned documents to a network share
  • copyman
    Owner / Technician
    • Sep 2005
    • 4721
    Re: BizHub C224e scan to SMB2 network share
    SMB Support for the following models.
    • bizhub 4/4e series machines support up to SMB 2.0 for printing and scanning.
    There is newer F/W that came out 4/22. GDT-M1
    I'm sure if you make a small donation to this website someone will send it to you. Or there is a member here who will sell it to you if you don't want to become a member and reap all the benefits offered on this forum.
    • techsxge
      • Jan 2022
      • 660
      lol thats weird. My Dealer portal only shows GDR-M1 and GDS-M1 03/2022. Is this special firmware you are talking about or is my dealer portal bugged
      • and
        • Oct 2011
        • 97
        GDF-M1 support SMB 2.0
        • fsck
          • Nov 2022
          • 3
          Our dealer said the same but no it doesn't. I can't find it in the menus and it will not scan to network folder which has SMB1 disabled. Scans to folder with SMB1 disabled are failing.
          • techsxge
            • Jan 2022
            • 660
            • fsck
              • Nov 2022
              • 3
              Originally posted by techsxge
              TIB:[ATTACH=CONFIG]55459[/ATTACH]
              Could you please elaborate with me on how to set DipSW accordingly?
              • techsxge
                • Jan 2022
                • 660
                contributing a small donation to this forum might unlock further help and information
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4721
                  A small donation is not much to ask considering all the expert advice here. You have already received a lot of free advice for FREE! No one here gets paid, the "small" donations help keep this site online.
                  • tsbservice
                    Field tech
                    • 8020
                    Agree. Most of the time I don't mind sharing with fellow tech but being a Contributor definitely helps as we all have received great advices and tips from another techs here.
                    • rrrohan
                      • Sep 2011
                      • 1977
                      What error do you get when scanning smb2
                      Did u turn smb1 on at pc and then scanning worked?
                      What fuction version are you running
                      • Reed
                        • Feb 2011
                        • 258
                        If you are having trouble getting a current firmware, you can always use an ftp program to scan to the network share.
                        • cayyell
                          • Feb 2013
                          • 85
                          I can confirm that your current firmware will works for SMB 2.0
                          but you will need to change it to function 7 in order for the SMB 2.0 to work. u may google it, there are some youtube out there.
                          • femaster
                            • May 2011
                            • 1514
                            If function version 7 is the key to your issue, change switch 25 to hex 60 which will enable function version 7.
                            • Synthohol
                              Certified Konica Expert
                              • 5847
                              here ya go, i always just change bit sw 219 to lock in smb2.0 and ntlm to 1/2 or 2
