Bizhub 4050i Making a loud noise
  • JasonSBE
    • Apr 2014
    • 183
    Well this is a strange one for me. The noise is coming from the fusing area. I replaced the fusing unit and the drive assembly. Still making the noise. I saw that the exit assembly is also driven by the fusing drive, but the noise is happening even when the exit drive is not engaged. Was thinking the next step would be to change the exit but I'm having doubts because the noise is happening regardless of whether or not the exit is engaged.
    Anyone ever have something like this come up on these machines before? I have a terrible track record with these style machines.
  • rrrohan
    • Sep 2011
    • 1977
    Re: Bizhub 4050i Making a loud noise
    id consider the ITBU. i had a customer complain about a noise that never occured when a tech would visit so i gave in and replaced the ITBU. havent heard a complaint since
    • JasonSBE
      • Apr 2014
      • 183
      Thank you for the suggestion, but it's not coming from the transfer belt it is definitely coming from the fuser drive. I verified this both by operating the machine with the panels off so I could watch through the crack in the back of the machine as well as jimmying the door and running tests in service mode
        • 22930
        Grease will help. See above: =^..^=
        • JasonSBE
          • Apr 2014
          • 183
          https://www.copytechnet.com/forums/k...ml#post2135896
          Thank you for this, I have one question. Will this cause noise to happen when the fusing unit is rotating but the exit is not engaged?
            • 22930
            IIRC exit unit and fuser run off the same motor ... both running at the same time regardless. =^..^=
            • JasonSBE
              • Apr 2014
              • 183
              The fusing drive has 1 motor, 1 solenoid, and two clutches. The solenoid operates the gate for duplex, and the two clutches engage for the exit and the duplex
              • mascan42
                • Oct 2008
                • 480
                This may help. Removing the exit unit can be a bit tricky.
                C3350i exit unit removal.pdf
                • JasonSBE
                  • Apr 2014
                  • 183
                  As usual, you guys came through. I greased the points mentioned and the machine is sounding normal again. Thanks for all the input.
                    • 22930
                    Congratilations on your success! Thanks for posting back. =^..^=
