C250i fusing problem
  • copyman
    replied
    Re: C250i fusing problem
    Not sure for this model but there is firmware for the 8 series addressing this issue mostly for 1st page after coming out of sleep mode.
    Have you gone into the service mode and increased the fusing temp?
    Aftermarket toner?
  • suomi
    replied
    Originally posted by EarthKmTech
    I've not had one last life yet, seem to have random blisters happening around the half way mark. Not impressed.
    No part has lasted as promised....
  • EarthKmTech
    replied
    We have seen this a lot, the fuser units on the i series seem to be very poor. The only option is to replace it.
    Hoping Konica Minolta come up with a modified version soon!.
  • jwai
    replied
    Originally posted by Markks
    I dont think it is a firmware issue but J9 is pretty old current firmware is N4. when you update firmware you also need to update function version. current function level is 2.1 you set it by setting sw25 to hex 30.
    as far as fusing make sure paper weight is set correctly
    Paper weight is correct, client only use 80gsm paper and plain paper is set on machine.
  • Ziggy
    replied
    Originally posted by jwai
    Hello,
    Several bizhub C250i sometimes have fusing problem, toner cannot fixed on paper.
    check the unit is ok, increased fusing temp. but no luck
    replace new unit solve it, what reason cause this?
    F/W G00-J9
    Fuser life more than 70%
    replied
    Hello,
    F/W G00-J9
  • jwai
    started a topic C250i fusing problem
    Hello,
    F/W G00-J9
