C364c locked out of Service and Web
  • FuserNoob
    Service Mgr, CISSP
    • Jul 2022
    • 162
    I have a KM C364e that we replaced with a newer model
    When i got it back to the shop i tried to run an initialize to wipe the machine
    I cannot access Service menu and when i try to access it from a browser it just times out.
    I can get to display keypad, but when i hit the 'start' button i get an error beep
    The client IT dept must have locket it out
    any thoughts?
    THANK YOU!
  • emujo2
    • Mar 2017
    • 1579
    Re: C364c locked out of Service and Web
    There may be a job stuck in the queue. There are only a few reasons you would not be able to access service mode..This and lack of the CE password are the only reasons I can think of, and if you can't access service mode via the control panel, why would you think the web page would work. The web page can be locked out in admin mode. Look for HTTP server enabled. E
    • FuserNoob
      Service Mgr, CISSP
      • Jul 2022
      • 162
      Job list is clear
      There are 2 items in the 'needs attention' - 'preparing scan/fax' and 'preparing user box'
      the machine has been powered on and the last reboot was prior to the holiday weekend
      Rebooted machine again and after 15 minutes still waiting on 'preparing scan/fax' and 'preparing user box'
      there are no error messages, it just seems to be stuck on those two items
      Also, the 'network' option is missing in Admin mode (as are several other menu options)
        • 23010
        It sounds like the HDD is wiped or removed, but still Set. =^..^=
        • emujo2
          • Mar 2017
          • 1579
          You may also get something like this when the NIC is not pulling an IP address properly..Have you tried connecting it to a DHCP enabled network? Or, letting it come to ready with the ethernet cable disconnected?
          • Synthohol
            Certified Konica Expert
            • 5891
            you can boot into trouble reset mode and see if you can access service mode from there.
            • FuserNoob
              Service Mgr, CISSP
              • Jul 2022
              • 162
              OK..
              It's getting an IP address on our LAN
              I disconnected the Ethernet cable and rebooted - same issue, wont get past 'preparing scan/fax' and 'preparing user box'
              I did a power-on self diagnostic, here is the result:
              Check ALL
              DIMM R/W Check
              WORK0 OK
              WORK1 OK
              FILE0 OK
              FILE1 OK
              FILE2 OK
              FILE3 OK
              FILE4 OK
              FILE5 OK
              On Board Memory Check
              R/W Check OK
              Pattern Check OK
              SDD Check
              R/W Check OK
              Pattern Check OK
              HDD Check
              R/W Check OK
              Pattern Check OK
              • JasonSBE
                • Apr 2014
                • 187
                in the first post you made you said you hit the "start" button. Not sure if this was a mistype or if you're hitting the wrong button. Power the machine off, hold down reset, and power it back on. Try to enter service mode from the trouble reset screen. You have to hit stop, not start.
                • FuserNoob
                  Service Mgr, CISSP
                  • Jul 2022
                  • 162
                  Curse these fat fingers - yes, i meant 'stop'
                  I tried accessing the service menu through trouble reset screen - no dice
                  • tsbservice
                    Field tech
                    • 8052
                    Why?
                    Do you see CE password screen or what?
                    • FuserNoob
                      Service Mgr, CISSP
                      • Jul 2022
                      • 162
                      trouble reset screen shows, from left to right, 'AES', 'Trouble Reset' and the Keypad
                      i only get error beeps when i touch 'stop' or any key on the keypad
                      • JasonSBE
                        • Apr 2014
                        • 187
                        There is something else going on here. Either something with the touch screen is not registering or the calibration is off or something else.... you can change the password to access service mode but not the method.
                        • femaster
                          • May 2011
                          • 1519
                          Even if you get error beeps while on the trouble reset screen, go through the whole key sequence for service mode. You should then be prompted to enter the password. Enter that and you should get in.
                          You can only touch the service mode keys in sequence. If you press anything else before hand, or fat finger the sequence, you will need to start over by boot into the trouble reset screen again.
                          • techsxge
                            • Jan 2022
                            • 660
                            pressing the rset utton also works for re-entering it
                            • femaster
                              • May 2011
                              • 1519
                              Thanks for that. I must have never tried pressing reset.
                              I know I've fat-fingered the sequence on a couple of occasions and had to start over to get it to go once that happened.
