Scan quality
  • cpuryear
    • Mar 2019
    • 15
    Scan quality
  • Synthohol
    Certified Konica Expert
    • 5845
    Re: Scan quality
    humidity on the mirrors or lens?
    does it do that off the glass as well or just ADF?
    • cpuryear
      • Mar 2019
      • 15
      Re: Scan quality
      Only through the ADF
      • Synthohol
        • 5845
        Re: Scan quality
        if it were me i'd start with the dual scan board in the back and reseat the hdmi cable on the mfpb.
        • cpuryear
          • Mar 2019
          • 15
          Re: Scan quality
          Thank you!
            • 23009
            Re: Scan quality
            I thought of humidity on the CCD or mirrors ... it fits your scenario of clearing up mid-morning ... especially in an unheated space overnight, but it wouldn't look like that.
            Your sample looks more like electrical interference. Maybe a poorly fitted ribbon to the CCD, or a high voltage cable lying across that ribbon. On other Konica Minoltas (read: Minolta engines) I've seen failed CCDs, especially in very high volume scanners on 754e's and 808's, but those usually code out, and clear or reset fine. Overheating seems to be the main factor there.
            You may also have a recurring AC power defect ... my example is a rail mounted electrical crane shared a circuit with my MFP. Simply moving the MFP to a separate circuit solved the issue. Your power quality analyzer should pick that up right away. Just leave it on a 48 hour cycle, you should get plenty of events to examine. =^..^=
            • tsbservice
              Field tech
              • 8020
              Re: Scan quality
              Exactly
              • Woxner
                • Jul 2011
                • 850
                Re: Scan quality
                I have sern several ccd's do this in am. After being used for a bit clears up and does not code
                I would replace ccd and possibly inverter pwb
                • SAR
                  • Jul 2009
                  • 203
                  Re: Scan quality
                  Bizhubd C364 wierd lines
                  This is one other possibility. I just had a similar problem on a C284e and replacing the printer control board fixed mine too.
