BizHub C227 color intensities
  • batmantas
    • Dec 2022
    • 3
    hello,
    BizHub C227 not prints colors 5, 10, 20% in demo page. Image appears very bright.
    Any ideas how solve this problem?
  • tech51
    • 846
    Re: BizHub C227 color intensities
    What have you done so far?
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      Looks a lot like an end user.
      New account, first post, extremely basic issue.
      • tech51
        • 846
        • tsbservice
          Field tech
          • 8002
          Bird looks awful what have you done to it?
          Readitlikeweneedmoreinfo.
          • batmantas
            • Dec 2022
            • 3
            Every couple months appears streaks on paper, after clean transfer belt everything works fine, but after last cleaning lost low intensity colors.
            Looks like waste toner not transfer to waste toner box. So why I often cleaning transfer belt, actually cleaning this part Capture.JPG
            • Synthohol
              Certified Konica Expert
              • Mar 2016
              • 5814
              reset background data & stabilize,
              then stabilize and gradations 3x each.
              • Gift
                • Mar 2011
                • 2459
                That cleaning blade of the ITB is probably too old so cleaning won't last long. You can buy these blades from some non OEM part suppliers to avoid swapping entire ITB units at service contract MFPs but I don't have any long time experience so far. Resetting stabilizing data and run a freh stabilization might help - I'd clean the AIDC sensores before that procedure though.
                • femaster
                  • May 2011
                  • 1492
                  As Synthohol stated, run the gradation per the instructions given and it should greatly improve your issue. Depending on consumable wear, it may not end up perfect, but should be a whole lot better than what you have now.
                  • batmantas
                    • Dec 2022
                    • 3
                    Thanks all for advices.
                    Initialize+Image Stabilization helped
                    • Todd Glenn
                      • May 2021
                      • 22
                      Konica Minolta had a bulletin for the ITB , solved with a firmware and version upgrade, and new ITB, but would go with others advice and just replace the blade, if possible.
