8 Series Drum Unit - Thick Black Line Bizhub 558
  • aberock
    • May 2022
    • 124
    Hi Guys ,
    Any one facing this problem before ? problem occur on Bizhub 558
    Changed drum , blade , sponge , charger roller and new chip . ( CET BRAND )
    Had changed all the part in drum unit but problem occur again after 10K usage or less .
    There is black thick line on charger roller and sponge .
    We replace to new part but problem will repeat again .
    Use original KM toner .
    Anybody got any idea for this issue?
  • Gift
    • Mar 2011
    • 2459
    Re: 8 Series Drum Unit - Thick Black Line Bizhub 558
    Oficially therte are no "parts for drum unit" - I suppose you refurbed it with crap parts or you made a mistake during the process. BK drum is not that expensive you an also use the cheaper "non longlife" ones for the C308.
    • aberock
      • May 2022
      • 124
      What mistake can caused this as you mention ?
      Don't think all oem part consider as crap part. some times oem part do save alot . not only genuine part work LOL!
      • Gift
        • Mar 2011
        • 2459
        I know, but it seems that either the cleaning blade isn't placed or working properly (did you lubricate it with toner?) or there's clogged toner inside the waste toner channel pressing against the drum. Guess you'll know after removing the drum and have a look.
        • tsbservice
          Field tech
          • 8013
          What if you put new original drum unit? Will it streaks after 5-10k prints... probably not. Like other member said I will start with change of supplier of parts to another maybe CET or Katun but not garage Alibaba...
          • copier tech
            • 8144
            Hi Guys ,
            [ATTACH=CONFIG]56181[/ATTACH][ATTACH=CONFIG]56182[/ATTACH]
            The 8 series are generally very reliable until you start using after market parts.
            Konica Minolta do long life drum for this model.
            DR315K Black Drum Unit Long Life A7U40RE
            • aberock
              • May 2022
              • 124
              i knew everyone like CET right .
              Used CET blade and drum . problem remain haha . im clueless now
              • and
                • Oct 2011
                • 96
                - high temperatures in the drum area? Check filter and check temperature of ambiental sensor.
                • tsbservice
                  Field tech
                  • 8013
                  Why not all parts CET?
                  • Gift
                    • Mar 2011
                    • 2459
                    Perhaps they made a bad batch - I made experiences with faulty blades for ricoh systems - the rubber edge wasn't produced smooth & even enough and if you lied it on a desk it was clearly uneven.
                    No reason to be clueless if everything is so obvious....
                    • Gaffers01
                      • May 2011
                      • 335
                      Check the development unit for any build ups I have had similar issue before, also make sure you chip the drum unit when replacing this is very important with these machine as it resets the charges.
                      • copyman
                        Owner / Technician
                        • Sep 2005
                        • 4700
                        Try different brand of aftermarket parts. Or like the others suggested just get a black drum which aren't that expensive. A reman aftermarket drum isn't much more than rebuilding yourself.
                        I rebuild "8" series drums all the time with aftermarket parts and last just as long if not longer then OEM drums. Drums with PCR's are crap! Doesn't matter if OEM or not. Might be ok for lower volume like small printers but not higher volume copiers. I'm sure Kon/Min wanted to sell more drums and didn't like how the "4" series drums lasted way past rated life!
                        • elmaligno
                          Expert technician KM
                          • Oct 2009
                          • 302
                          Hi Guys ,
                          In my experience this problem occurs in both original and rebuilt units. Some originals fail even with 30k impressions or less. Even the manufacturer has changed the black foam cleaning brush for a spiral brush (they are aware of the problem) with no good result.
                          And referring to the comments I read about the long life drum, apart from the fact that nobody says they have to have a minimum firmware version from which they can be used, they don't last anywhere near that "extra long life".
                          That's my experience...and I have hundreds of machines wish models.....
                          Field technician since 1994
                          • Gift
                            • Mar 2011
                            • 2459
                            I also think this longlife drum is not worth the extra money in most cases. It's basicly identical but with the "spiral cleaning" roller that is suppose to allow higher yields and a different chip of course so the FW does detect it and apply the correct yield target to it.
                            • aberock
                              • May 2022
                              • 124
                              Possible drum chip effect the drum charge caused this issue?
                              Used 4 series chip for this experiment.
                              But 4 and 8 series chip compatible right?
