Fiery E100-02 IC-413 For KM Bizhub Press C7000P
  • Danny9279
    • Feb 2022
    • 15
    [Dead] Fiery E100-02 IC-413 For KM Bizhub Press C7000P
  • tulintron
    • Jul 2014
    • 668
    Re: Fiery E100-02 IC-413 For KM Bizhub Press C7000P
    It is certain that your OS has become corrupted. Need to reinstall OS Fiery.
    https://www.copytechnet.com/images/smilies/cool.pngNada como dia após diahttps://www.copytechnet.com/images/smilies/cool.png
    • Synthohol
      Certified Konica Expert
      • Mar 2016
      • 5808
      a corrupt OS will cause AA.
      replace the HDD and run system software install.
      • tulintron
        • Jul 2014
        • 668
        Looks like you already helped him yesterday. I arrived late.
        • Danny9279
          • Feb 2022
          • 15
          Replaced the Hdd and ran the install. When starting up it runs fine upto the start up screen with the Win XP logo, after this it's just black screen and a 02 code on the LED. I have a spare PC that I'm going to runthe install on and see if it runs without issues.
          • tulintron
            • Jul 2014
            • 668
            Is it running OS over USB?
            • Synthohol
              • Mar 2016
              • 5808
              unless there was a FACI kit then yes after the XP logo it is supposed to go blank.
              it can take half an hour for it to fully install and go to 00
              which method did you use? network or USB?
              • Danny9279
                • Feb 2022
                • 15
                I used the USB method. I left it running all night and this morning it was still 02 error code on the LED.
                I apologize ahead of time, what is a FACI Kit?
                • Danny9279
                  • Feb 2022
                  • 15
                  I installed directly to the HDD using USB method
                  • Synthohol
                    • Mar 2016
                    • 5808
                    for 20+ years i have always used the crossover cable method.
                    this way i can watch the progress of the install and it just works everytime.
                    dont forget to move the 2 service switches for this and moved back when install complete.
                    i mount the .iso with PowerIso and run the installer.vbs file and follow the prompts.
                    with todays network cards you dont even need a crossover, straight cable will figure it out itself.
                    • tulintron
                      • Jul 2014
                      • 668
                      Like Synthohol mentioned, it takes 30 minutes if you do it via USB. FACI kit gives you video permission. No it, no video driver.
                      You may have misconfigured SW switch 1 and 2 on the Fiery controller enclosure or incorrectly installed the iso image onto the USB memory.
                      If you do the correct step of the ISO image on the USB memory, switch the DIPSW switch correctly and turn on the Fiery, in 40 minutes you have a new Fiery system to work with. Try clearing the RAM.
                      • Danny9279
                        • Feb 2022
                        • 15
                        I brought the Fiery to my office. It connected with a straight thru to my laptop. I run the installer and I get the following error.
                        "You must exit all application services using by tftp, and try again."
                        How do I go about changing the IP for the Fiery to be able to connect to the laptop running the ISO?
                        • tulintron
                          • Jul 2014
                          • 668
                          You cannot change the Fiery's ip because it has no system. You must put the PC's ip as DHCP and let both connect. Usually it is the IP 127.0.0.1
                          • Danny9279
                            • Feb 2022
                            • 15
                            Thanks, but I actually set the TFTP IP Scheme to 192.168.1.1/24
                            Now the TFTP is giving a PXE-E32: TFTP open Timeout.
                            • Synthohol
                              • Mar 2016
                              • 5808
                              yes, from a command prompt type services.msc and stop any ftp service running then run the installer again.
                              also set your nic fro dhcp, it will find the fiery. even if you see 169.254 or 0.0.0.0. just select whichever one is the hardware nic not the wifi nic
