C300i C2255
  • jwai
    • May 2018
    • 517
    C300i C2255
    Hello,
    One C300i has 30K prints, it showed C2255 error code,
    checked CYM developing unit rotation OK, developing unit motor rotation OK,
    opened and closed front door and that code displayed immediately,
    would be faulty developing unit driving motor or control board?
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 302
    Re: C300i C2255
    Originally posted by jwai
    Hello,
    How do you know that everything you say is ok? What tests did you carry out for it?
    Field technician since 1994
    • Ziggy
      • Feb 2018
      • 801
      Re: C300i C2255
      Hello,
      • REGSIS
        • May 2016
        • 435
        Re: C300i C2255
        Hello,
        Check developing unit and toner hopper.
        I had a C308 with C2557 on 1k prints. A piece of metal was stucked between gears on K hopper.
        Might be a defective developing unit Y.
        • jwai
          • May 2018
          • 517
          Re: C300i C2255
          I removed CYM developing units and turned gears manually, drove smooth.
          After that I removed M21 and turned it, OK, installed it and turned again with drive section, no problem.
