Issue with Bizhub C759 and fiery IC-418
  • otphas
    • Aug 2019
    • 127
    When we start the machine and try to enter in the Fiery menu came this message 0-02-05-a50cff80e4e26e32897ebea39497a79c1acf5f0396e216a7486565ab766129df_c705be577c83c8b9.jpg any idea ? Fiery is 00 and all cables are connected !
  • Synthohol
    Certified Konica Expert
    • 5908
    Re: Issue with Bizhub C759 and fiery IC-418
    Problem
    IC-416/IC-418, "Unable to connect" message.
    Solution
    CAUSE: Connection issue between the IC-416 or IC-418 and the machine.
    SOLUTION: Set both the IC-416 or IC-418 and the machine NIC speeds to 100 full duplex.
    Problem
    "Controller Not Connected" message may occur after installation.
    Solution
    CAUSE: Possible loose connection of the video interface cable
    SOLUTION: During hardware setup on some Fiery installs, route the VI-510 to Fiery cable through a nearby wiring saddle allowing for a more secure connection.
    • Ziggy
      • Feb 2018
      • 810
      Originally posted by otphas
      When we start the machine and try to enter in the Fiery menu came this message [ATTACH=CONFIG]56478[/ATTACH] any idea ? Fiery is 00 and all cables are connected !
      If its a new install follow the attached instructions. They are for an eight series but I have found they work with all the newer models even the i-series. also if you are new to firey just know even after it reaches 00 it still could take up to 15 minutes before Fiery comes to full ready. I've even had them take up to 30 minutes. Plus make sure your copier has latest firmware
      • Ziggy
        • Feb 2018
        • 810
        Just discovered this install supplement see attached
        • emujo2
          • Mar 2017
          • 1579
          Is this a new build, or was it working and just started this behavior? If you know the IP of the Fiery, can you web into it? What method did you use to set this up? Separate IPs, or obtain IP for engine? E
          • otphas
            • Aug 2019
            • 127
            We just import the machine and start it. We dont know the history of the machine. We dont know the Fiery's IP, tomorrow i will try to fix it and come back to you .
            • Synthohol
              • 5908
              if you can see the fiery icon in the menu page thats where you print the controller config page otherwise the copiers ip may just be 1 notch above the fiery IP
