Bizhub 958
  • big jase
    • Jul 2008
    • 136
    Bizhub 958
    PCQ, we have replaced drum and dev unit but still have this issueWhatsApp Image 2023-01-26 at 10.00.40.jpg
    has any one seen this before
    If at First you don't succeed remove all evidence of ever trying!
  • big jase
    • Jul 2008
    • 136
    Re: Bizhub 958
    Originally posted by big jase
    PCQ, we have replaced drium and dev unit but still have this issue[ATTACH=CONFIG]56505[/ATTACH]
    its the random white dots not the lighter area , that is just engineers camera
    • Synthohol
      Certified Konica Expert
      • 5823
      Re: Bizhub 958
      looks like repeating marks. if you roll the paper so the matching marks are on top of each other you now have the diameter of the offending item.
      • tsbservice
        Field tech
        • 8009
        Re: Bizhub 958
        Have you consulted with your manual image trouble section, white dots/blotched image are typically related to second transfer voltage.
          • 23007
          Re: Bizhub 958
          White spots can be the result of the drum arcing to the primary charge roller or to the developing roller.
          If those were new units, it should have resolved the issue. Maybe transfer roller? Did you reset the appropriate counters and do a gradation or three? =^..^=
          • elmaligno
            Expert technician KM
            • Oct 2009
            • 302
            Re: Bizhub 958
            PCQ, we have replaced drum and dev unit but still have this issue[ATTACH=CONFIG]56505[/ATTACH]
            it happened to me many times. it's the transfer band.
            Field technician since 1994
            • Rolandito
              • Aug 2007
              • 90
              Re: Bizhub 958
              please send scanned document, to check correctly
              • femaster
                • May 2011
                • 1504
                Re: Bizhub 958
                Your image is REALLY small, so it's hard to determine for sure. My question, how over-life is the transfer belt? I have seen tiny white areas all over the solid black sections on older machines (ala 552/652 machines) when the T-belts are way over life because eventually the roller behind the belt gets a buildup on it. In this case, replacing the belt eliminates the problem.
                It can also be slightly mitigated by changing the primary transfer voltages. Personally I'd try changing the voltages and see if the problem gets worse and/or better. If it does, then the most likely issue is with buildup on that roller, so I'd replace the T-Belt at that point. Don't use the voltage adjustment to try and stretch more life out of the belt, in the end you will cause more harm than good doing that.
                  Re: Bizhub 958
                  AMEN!!!
                  • zayonc
                    • Jan 2022
                    • 49
                    Re: Bizhub 958
                    this was the Transfer Belt ~140%
