Konica Minolta C454e Black Image
  • mearmi
    • Oct 2010
    • 346
    [Misc] Konica Minolta C454e Black Image
    Transfer Belt and Transfer Roller is full of toner. After cleaning it works for couple of hours. But got the problem again.
    If manually rotate the belt, it is cleaning well.
    Kindly advise.
    Thanks a lot
  • copyman
    Owner / Technician
    • Sep 2005
    • 4646
    Re: Konica Minolta C454e Black Image
    Have you tried another K drum?
    Is the transfer belt cleaning unit packed with toner? The waste toner chute can get clogged on the "4" series and back up into TB cleaning unit. Usually you will hear loud chatter noise from gears binding.
    • mearmi
      • Oct 2010
      • 346
      Thanks for your response.
      Yes replaced Drum and developer unit. And Transfer belt cleaning unit is not packed with toner.
      thanks
        • 22999
        If there are image voids, it's either the laser or the image processing board.
        If there are no image voids it's primary charge loss.
        We won't be able to tell that from your scan, since the scanner creates it's own image voids. =^..^=
        • tsbservice
          Field tech
          • 7986
          1.Stop machine mid copy and check image before fuser.
          2.Other colors OK?
          • 40yearsplus
            • May 2020
            • 113
            Not an expert on this but it sounds like your waste auger is not moving or driving if you have found its not clogged already. If I read your post properly check the waste auger drive.
            Don't rotate the belt I assume the waste has a gear that hits something to drive it. whatever it meshes with.
            • 40yearsplus
              • May 2020
              • 113
              I read you said it was not packed id you replace the itb unit yet. Sorry if these are off topic and you tried them.
              • tech51
                • 846
                • tsbservice
                  Field tech
                  • 7986
                  Please ignore my previous comment. If prints are black then BC and tech51 had some excellent advices for you.
                  • mearmi
                    • Oct 2010
                    • 346
                    You are Right. It was waste auger that was not driving properly. Fixed the issue.
                    Thanks a lot
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4646
                      Thanks a lot
                      Thanks for following up. From your OP it was obvious had something to do with waste toner not moving. It's usually something simple on the 4 series with print quality and very rare boards, print heads, etc that are bad.
