konica C458 message
  • acsolutions
    • Jun 2010
    • 519
    [Misc] konica C458 message
    Hello, when copying and scanning from document feeder or on the glass I get a message "failed to complete job. Please check job history" it comes and goes. Some times after trying on glass or through feeder a dozen times it will finally work. Even after rebooting machine same issue occurs, its random! Trying Scan to email same issue. No scan to pc is setup. Once problem goes away copying and scanning work fine. Any suggestions would be great. Thanks
    • 23010
    Re: konica C458 message
    Did you look at the scan history? Usually there is a code that gives a clue as to why it failed. =^..^=
    • acsolutions
      • Jun 2010
      • 519
      Here's the message.
      • and
        • Oct 2011
        • 99
        I receved "Error code 0" when from remote a try to scan an empty glass with "remove blank page" enabled.
        • kingarthur
          • 1385
          yep, looks like "blank page removal" is set as default - the machine is doing what its asked
          • emujo2
            • Mar 2017
            • 1579
            The entire job should not delete unless it's all made up of blank pages..I see that you are using authentication. I would double check what is or is not allowed..Maybe you have full color scanning restricted for a user..E
            • tsbservice
              Field tech
              • 8052
              Try system error clear from service mode. If anything else fails backup settings and do Clear All Data.
