KM Bizhub Press C7000P
  • Danny9279
    • Feb 2022
    • 15
    [Error Code] KM Bizhub Press C7000P
    Hi guys,
    Im currently getting a few errors on my KM Biz Press C7000. According to the service manual its a few things that can fix it but Im unable to find a proper parts list with Parts Number. These are the errors that are popping up at the moment.
    C-0201 (Paper Tray 1) For this one Im guessing its either the Upper Limit Sensor /1 (PS30) or the Paper lift motor /1 (M38)
    C-3509 (Fusing Unit) Im inclined to replace the TEMPERATURE SENSOR 1 TH1. This because previously I was getting the C-3912 error code and I replaced the TEMPERATURE SENSOR 2 TH2 and the Thermostat and it worked for a minute or so before getting the C-3509 error.
    Any assist would be appreciated.
  • Synthohol
    Certified Konica Expert
    • 5868
    Re: KM Bizhub Press C7000P
    PM sent.
    thanks for contributing!
    • wjurls
      • Feb 2017
      • 498
      Your tray one lift error, providing it isn't a binding limit actuator, is most likely a failed lift unit aka "Brush Motor" A0P0M10000. It is pretty invasive work to change it out. You might want to hire a competent technician to replace it for you.
