Bizhup 223 C-2650
    • 14813
    [Error Code] Bizhup 223 C-2650
    Hello everyone
    I know it's old and should be replaced (try to tell the customer that lol)
    I have a C-2650 error. I have replaced the PRCB and updated the firmware without success. Next on the list is the eeprom but I can't find a part number for it. I'm not a KM dealer so I was hoping someone would be able to supply the part number.
    Thanks very much.
  • Ziggy
    • Feb 2018
    • 780
    Re: Bizhup 223 C-2650
    Hello everyone
    Thanks very much.
    Did you pull eeprom off the original board and put on the new PRCB?
    Error
    C2650
    Root Cause
    C2650 code at machine power up after replacing the PRCB.
    Workaround/Fix
    CAUSE: The IC51 EEPROM was not swapped from the original PRCB to the current PRCB.
    SOLUTION: Remove the IC51 EEPROM from the original PRCB and install the chip onto the current PRCB
    NOTE• When the printer control board(PRCB) has been replaced, be sureto remount EEPROM (IC51) [1].Remove EEPROM (IC51) [1] fromthe old printer control board andmount it on the new printer controlboard.NOTE• When mounting EEPROM (IC51),align the notches (indicated by “A”in the illustration).NOTE• When the printer control board is to be replaced, rewriting the firmware to the latest one.
      • 14813
      Error
      C2650
      Root Cause
      Workaround/Fix
      Yes.
      Error code c2650 before board change, c2650 after board change.
      • femaster
        • May 2011
        • 1514
        The actual EEPROM doesn't show up in the parts catalog. That may be one of those items that is only available to be purchased once KM's technical support line staff have recommended it's replacement. There are some items only available that way.
          • 14813
          I was hoping that if someone had previously replaced one they may still have the part number.
          • Ziggy
            • Feb 2018
            • 780
            Yes.
            Eeprom can only be ordered through SSD . They don't just send them out because they don't want people resetting meters on machines
