BizHub C458 through Fiery IC-416 secondary Ethernet?
  • Mayhem
    • Mar 2023
    • 1
  • Synthohol
    Certified Konica Expert
    • 5735
    • emujo2
      • Mar 2017
      • 1580
      Re: BizHub C458 through Fiery IC-416 secondary Ethernet?
      One thing of note..You must use a crossover cable to connect the Fiery to the MPF this way..IMHO you should leave it the way it is..Separating the Emperon from the Fiery gives you printing regardless of the Fiery..IF the Fiery is down and you are running the way you mention then you will also lose the Emperon..Were you able to access the Fiery from the CP beofre you made the changes? E
      • Synthohol
        • 5735
        all nics are auto-crossover now. ive used a straight cable a whole bunch of times but if it comes with one yes, use it.
        • emujo2
          • Mar 2017
          • 1580
          My EFI rep would say.
          If it says connect crossover cable, use the crossover cable
          He also says that EFI uses a HDD with a particular set of charecteristics, simply popping in an off the shelf HDD may not work. In some cases you have to purchase the EFI HDD. E
          • Ziggy
            • Feb 2018
            • 679
            As far as the hard drive is concerned you can replace it with a SSD with no trouble, I do this all the time. Fiery boots much faster and SSD wont fail as fast as a regular HDD. Im also attaching instructions on how to hook up a Fiery to an eight series. I always follow the 1 page document first IC-416_418_InstallationManualSupplementVer1.0+(1).pdfIC-416 Setup On 8 Series.pdf
