Bizhub 4050 CE Password reset
  • ionutkok
    • Nov 2012
    • 24
    How can I reset the service CE password on Bizhub 4050 ? 92729272 not working. I tried 9272, 12345678, 00000000 ...not working.
    Thank's
  • Brad6784
    • Mar 2015
    • 77
    Re: Bizhub 4050 CE Password reset
    Thank's
    Did you try 9272927292729272 (9272 x4) it is normally that on the later machines.
    • ionutkok
      • Nov 2012
      • 24
      Not working.
      I need a Restoration Tool
      • byronf
        Senior Member
        • Sep 2017
        • 109
        have you tried releasing the access lock?
        4.1.3 Procedure for releasing access lock
        1. Touch Menu.
        2. Touch [Counter].
        3. Touch [Keypad].
        4. Press the following keys in this order.
        Stop -> 0 -> 9 -> 3 -> 1 -> 7
        (With this procedure, activate the access lock release timer to start timing.)
        5. When five minutes has elapsed after activating the access lock release timer, the access lock will be released.
        try the standard password after that.
        3 wrong attempts you'd get locked out again.
        • ionutkok
          • Nov 2012
          • 24
          1. Touch Menu.
          2. Touch [Counter].
          3. Touch [Keypad].
          I know this procedure.
          The password has been changed and no other combination work
          • tsbservice
            Field tech
            • 8016
            Default on the this model is 9272x2
            Are you sure display is working correctly those are known to fail. Make sure pressing 9,2,7 is doing what it should.
            This is Lexmark machine basically in KM body so I don't know any kung-fu fancy reset working.
            • Ziggy
              • Feb 2018
              • 732
              Try this
              Model: bizhub 4050
              Code: Service Mode Password Lock Out
              Note: Print configuration page to backup system settings this procedure it won't wipe off any network settings or address book.
              Utility > User Settings > Printer Settings > Print Report > Configuration Page > Print
              After you printed the configuration page perform the following:
              1. Touch Utility
              2. Touch Administrator settings and login with default password 12345678.
              3. Touch Security Settings > Security Details Settings > Initialize > Restore System
              4. Machine will reboot
              • tsbservice
                Field tech
                • 8016
                Originally posted by Markks
                Try this
                Model: bizhub 4050
                1. Touch Utility
                On real KM machine resetting service password through admin settings will never gonna work (I hope).
                • ionutkok
                  • Nov 2012
                  • 24
                  Try this
                  Model: bizhub 4050
                  1. Touch Utility
                  Not Working !
                  • Synthohol
                    Certified Konica Expert
                    • 5824
                    NOTE• Access attempts to the Service Mode with a CE password is limited to up to 3 times.If the number of invalid access attempts reaches three, your access is locked. Until access lock is released, the Service Mode is not accessible.To release access lock, turning OFF/ON the power switch and rebooting the machine is necessary. (When the machine is rebooted, the invalid access attempts count is cleared.)For the procedure to release the access lock, see “I.4.1.3 Procedure for releasing access lock.” • The service code entered is displayed as “ * ”.
                    4.1.3 Procedure for releasing access lock1. Touch Menu.2. Touch [Counter].3. Touch [Keypad].4. Press the following keys in this order.Stop -> 0 -> 9 -> 3 -> 1 -> 7(With this procedure, activate the access lock release timer to start timing.)5. When five minutes has elapsed after activating the access lock release timer, the access lock will be released.
                    be patient, cannot rush this.
                    Question
                    How to unlock CE password when multiple invalid attempts have been made?
                    Answer
                    Perform the steps below.
                    1. Select Counter
                    2. Select Keypad
                    3. Press Stop ->0->9->3->1->7 (You will not see the screen change)
                    Note: Wait a MINIMUM of 5 minutes
                    4. Power off the Machine, wait 10 seconds and turn the machine back on
                    Note: You will now be able to use the default (92729272) password to access Service Mode
                    • ionutkok
                      • Nov 2012
                      • 24
                      This is procedure for releasing access .... Not for reset CE Password .... I need a tool or a secret code to reset CE Password ...
                      • Synthohol
                        • 5824
                        but if its locked out from 3 wrong tries have you unlocked it between sessions and waited the full 5 minutes?
                        • tsbservice
                          Field tech
                          • 8016
                          I never tested it but on this model I never heard of reset tool and really doubt reset code from LMS will work too.
