C458 ADF Left Cover Adjustment
  • FuserNoob
    Service Mgr, CISSP
    • Jul 2022
    • 149
    Hi All,
    I have a C458 that wont scan from the ADF unless I press down on the left cover.
    I have determined, after removing the rear cover, that the drive gear for the paper pickup assembly is not making contact with the take-up clutch gear.
    I cant find anything in mobile manuals covering this adjustment.
    Any help is appreciated.
    Thanks!
  • FuserNoob
    Service Mgr, CISSP
    • Jul 2022
    • 149
    Re: C458 ADF Left Cover Adjustment
    As a temporary fix, I was able to get it working by stripping the plastic cover off the wire of a bread tie and wrapping it around the post that the cover latches to, but I'd prefer something permanent.
      • 23008
      Is that post cracked or damaged in some way? It's not unheard of. =^..^=
      • FuserNoob
        Service Mgr, CISSP
        • Jul 2022
        • 149
        the metal post that the plastic hook from the cover attaches to is fine and there is no visible damage to the ADF
        • KMFLT3CH
          • May 2017
          • 237
          Try bending the metal post downwards. Had to do this on a few i-series right out of the box, otherwise you get a loud grinding noise and the original doesn't feed in.
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            Yep +1 this
            Seen this plenty when people try lifting open the jam access door without unlatching it. This is a 100% fix.
            Also helps with the 6633 jams resulting from insufficient separation pressure, slippery paper with high coverage printing and slipping on pickup on the DF-714's
            • femaster
              • May 2011
              • 1504
              So the plastic latch (hook) itself on the back side of the access door is still OK? I have seen those break many times on various models which results in exactly what you are experiencing.
              • FuserNoob
                Service Mgr, CISSP
                • Jul 2022
                • 149
                Everything looks fine upon visual inspection. I had to take off the back cover to diagnose that the gears weren't meshing correctly.
                I bent the pins (front and rear), i had to put some effort into closing the cover, but it scans like a champ now!
                Thanks!
