BizHub C450i scan settings
  • copyman
    Owner / Technician
    • Sep 2005
    • 4633
    Not sure if I posted about this before but still having an issue. When scanning a large amount of originals message comes up "job has been deleted due to insufficient memory".
    I'm sure it has to do with not being set to compact pdf but it will not let you to select "compact PDF" when set to B&W. Many of the original are printed on blue paper and why customer wants to scan in B&W. Resolution is set to 200dpi
    Thanks in advance
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5806
    Re: BizHub C450i scan settings
    i serviced a school system that loved blue paper. i had to set background removal to -4 on all the machines.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4633
      Thanks will keep that in mind. Any idea why compact PDF can't be selected when scanning B&W?
      • davidmtupper
        • Jul 2021
        • 326
        B&W is already pretty compact, being 8 bits per pixel max as opposed to 24 for full color. If it's true B&W, not gray scale, that goes down to 1 BPP.
        • Woxner
          • Jul 2011
          • 841
          is this scan to email smb or ftp. you can set the binary to 15 and when it hits that it divides it into another email. smb and ftp has no real limits.
          compact pdf only does gray scale for blk. its still blk. but yeah set the background removal.
          • copyman
            Owner / Technician
            • Sep 2005
            • 4633
            Background removal worked! Thanks to everyone especially Synthohol
