Konica BH C754e with FS-534 finisher can i set all copyto deliver to the inner tray?
  • tonerjockey
    • Apr 2014
    • 553
    #16
    Re: Konica BH C754e with FS-534 finisher can i set all copyto deliver to the inner tr
    clarification needed. is the AFAIK the paper exit section unit or the compiler? there is a stapler, and i am forgetting if this one has the hole punch on it.
    i have the FN-534 parts book, but not the service manual for that one. but looking. many time's, the service manual is called, get out there with your Philips and getter done.
    sorry for the pull on resources from you guys.
    • femaster
      • May 2011
      • 1458
      #17
      Originally posted by tonerjockey
      PS, femaster, do you remember the model of the copier in that old brochure? i am wondering if i have seen it way back.
      What exactly is it that you are referring to here? Are you talking about the image on the left side of my posts, under my forum name? If so, the model is right on the top of the image, MinoltaFax 1114. And actually if I remember correctly, that is an old ad out of Playboy magazine.
      Do you have the service manual for the C754e? If so, you already have most of what you need for the finisher. There is a Theory of Operation section as well as disassembly information for the finisher in the service manual of the copier,. If you go to section G in the copier's service manual (Disassembly/Reassembly), then open up section 5 under that titled "Option" you will find disassembly instructions for just about everything in there, including the FS-534.
      • tonerjockey
        • Apr 2014
        • 553
        #18
        Hi femaster. i thought i did. i am looking but my eyes aren't seeing it in my vast data base.
        i was fortunate enough to have a fellow specialist help me with the detailed procedure to get at that unit in a manner that wont damage it taking a possibly much faster percussive approach.
        i think it may be a great idea to have it in case i run into problems. if i locate it, your pointing me in the right direction to the chapter will definitely help.
        much appreciated, Jim
        • KMFLT3CH
          • May 2017
          • 207
          #19
          "AFAIK" is just an informal abbreviation for As far as I know. It's not any part of the machine or finisher.
          • tonerjockey
            • Apr 2014
            • 553
            #20
            that's too too funny. o guess you could say lmao...
            i need to get with the program.
            thank you for setting me strait.
            i want to find the ? 60s or 70s brochure cover for the Xerox 660 with the modern girl and the hairdo i have somewhere.
            yours brought that memory.
            priceless.
            • Synthohol
              Certified Konica Expert
              • 5735
              #21
              from Products – Memories of RXMP
              • tonerjockey
                • Apr 2014
                • 553
                #22
                Hey synthohol, great picture. actually the one i have is the same machine, but i think its older by my memory of the hair.
                i will try to find it. thanks that's a cool blast from the past.
                and i did work on some of those. the 660 i think was from ? early 60's. when i did them in the early 80's, they had took a microfiche reader and put it on top. so it copied the fiche.
                the word was the originals were referred to as a "Dial-a Fire" because like the later Xerox color 6500, they used a toaster radiant heat fuser. and when you had a jam, yep. they used monofilament fishing line across the exit of the fuser and a fire would melt it, opening an inter lock switch, and allowing a little door like trough to close and snuff out the fire. you hoped.
                660, for 660 copies an hour. the knob looked like a washing machine knob. and the sound it made was so funny.
                Happy Friday.
                • tsbservice
                  Field tech
                  • 7910
                  #23
                  Originally posted by Synthohol
                  from
                  Sorry Synth this time like goes for the girl... you get rep up
                  • tonerjockey
                    • Apr 2014
                    • 553
                    #24
                    actually i think it was dial a jam.
                    i think my brain is jammed. with toner...
                    • emujo2
                      • Mar 2017
                      • 1580
                      #25
                      Why don't you just isolate the finisher in service mode..You will lose all staple and sort functions, and paper should just exit to top tray..This may not work with the flat top finisher. also, there was an option you could add to the bridge that gave you a output tray right above the bridge unit. E
                      • tonerjockey
                        • Apr 2014
                        • 553
                        #26
                        oh, sorry emojo2, i was commenting on the old Xerox 660 dial a jam.
                        as for the finisher, i had found the fix here, and i made the metal strips for it.
                        then i left several messages to the customer that i am able to resolve the finisher jams. the man was seemingly a little off the last several times i was there, and the secretary would take a week or two to reply to me.
                        so, that is what's happening with the finisher. if he just wants to keep it cheap, i will try going back into admin mode and turn on i think it was tray 3. ill have to read my notes.
                        but thank you. if i get back there, and have an issue, i will attempt your suggestion.
                        have a nice holiday.
                        • Synthohol
                          • 5735
                          #27
                          when they get the OT tray there is a fan unit that gets installed and i think it may tell the machine how to exit?
                          • tonerjockey
                            • Apr 2014
                            • 553
                            #28
                            Cool, thanks synthohol.
                            have a nice day.
