Bizhub C458 - the purpose of the HDD and mSATA card?
  • JERI
    • Apr 2023
    • 6
    Hi all,
    I bought a used C458 which I started to dissassemble to see if I could repair it.
    I found there is a 2.5" HDD inside it, and also a small removable mSATA (?) card in it.
    My questions are, what's the purpose of both these two storage devices inside this kind of printer? I think maybe it would be possible to send a printjob over network to the printer and it is queued a while before printing.
    But I could be wrong.
    /Jeri
  • davidmtupper
    • Jul 2021
    • 326
    Re: Bizhub C458 - the purpose of the HDD and mSATA card?
    That's part of it. They are also used as temp storage for scanning and storage of certain data files required by the copier (movie files and pdf/a info in particular, maybe others). Also used for storing the document box(es), when you scan a doc in so it can be printed on demand at the copier.
    • Ziggy
      • Feb 2018
      • 802
      Originally posted by JERI
      Hi all,
      /Jeri
      I've never saw a 2nd hdd or mSATA in a machine but if memory servers me right the 2nd hdd is just there as a backup in case the 1st one fails. as far as the mSATA I have no clue
      • tsbservice
        Field tech
        • 8052
        By mSATA card he probably means eMMC.
        • JERI
          • Apr 2023
          • 6
          Yes, it seems to be a small SSD card with a eMMC chip on it, found the same one here:
          Original A7ahk12e00 Copier Parts Ssd Card Pwb-ssd Card For Konica Minolta Bizhub C308 C258 C368 C458 C558 C658 - Buy Konica Minolta C308 C258 C368 C458 C558 C658 Ssd Card,Konica Minolta Ssd Card,Pwb-ssd Card For Konica Minolta Bizhub C308 C258 C368 C458 C558 C658 Product on Alibaba.com
          So I get it the copier needs some temp storage of print jobs and holding print jobs for the right user to come up to the printer and maybe swipe a card to get the print out, and the 2.5" disk is the main part storage? What part is holding the printer's operating system?
          But what about that SSD card? I see a risk of buying and selling printers like this if there could be jobs stored on the hdd/ssd that never got printed?
          • Gift
            • Mar 2011
            • 2459
            I think the mSATA card is just an alternative for using NVRams. Guess it contains some "BIOS" like informations and internal data and some stuff to avoid cheating.
            • strider5555
              • Jun 2008
              • 96
              The 2.5 HDD is there for user boxes, as well as to store the address book, movie data, ocr font data, voice data, and is required if the machine has a fax, probably also needed for scanning (not sure on that). The eMMC board is the NVRAM for the machine. It has some limited storage, and contains serial numbers, total counters, machine settings, consumable counts, etc. It also stores adf adjustment backup, and other backup data. If this fails, it has to be ordered from KM. Hope that answers some questions.
              • Ziggy
                • Feb 2018
                • 802
                On Konica Minoltas the print jobs do not go to the hard drive at all. The only thing stored on hard drive is address book and any documents stored in a user box by the customer. The print jobs use ram so they are never stored on the machine. As far as the user boxes are concerned a customer should never store sensitive documents in a user box.
                • Synthohol
                  Certified Konica Expert
                  • 5892
                  are you sure about that?
                  • Ziggy
                    • Feb 2018
                    • 802
                    I stand corrected. I was told my information by a KM trainer. It might have been on a specific model. Thanks for the clarification
                    • tsbservice
                      Field tech
                      • 8052
                      Test machine C308.
                      - Clear all data(HDD after that is Not Installed).
                      - No matter if Spool Print Jobs in HDD before RIP is OFF or ON I can print on that machine.
                      The Owls Are Not What They Seem
                      • Synthohol
                        • 5892
                        of course you can print to it without the hdd, the statement i responded to was the inference that it doesn't use the spool on the copier hdd at all when that setting actually speeds up printing.
                        • JERI
                          • Apr 2023
                          • 6
                          I thought a print job was sent from the user's computer to his/her user box in the printer's hdd and then stored there until they walk up to the machine and hold their security card to have it printed. Then it get's erased?
                          • Synthohol
                            • 5892
                            thats only one type of environment.
                            when security is not needed print jobs just come right out like any other printer.
                            • JERI
                              • Apr 2023
                              • 6
                              Does anybody know what filesystem the hdd has? I am looking at it offline, and get it is a Linux but not exactly which kind.
                              Might be due to possible encryption, but at least I see the partitions.
