Konica Minolta C454E Noice when pritning
  • christian8220
    • Jul 2020
    • 53
    Konica Minolta C454 noise - YouTube
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5805
    Re: Konica Minolta C454E Noice when pritning
    your transfer belt waste area is clogged causing gears on the cleaning unit to skip the gear teeth.
    remove the cleaning assy and vacuum the chunks out and clean the chute between the trans belt and the WTB.
    thats your noise.
    also, just a hint to save time, remove the black guide from the trans belt and you can remove the belt without taking out the fuser first. (ive seen too many techs work too hard)
    • copyman
      Owner / Technician
      • Sep 2005
      • 4632
      See attached
      • Synthohol
        • Mar 2016
        • 5805
        hey, thanks for the backup document!
        tossed ya a rep point for that one
        • christian8220
          • Jul 2020
          • 53
          Thank you so much. I will look at it later today. I remember that I took out the toner waste box and the seal was not sitting as it was supposed to do. So, everything gives sense now.
          • tech51
            • 846
            • Hansoon
              • Sep 2007
              • 3374
              **OFF TOPIC**
              How can one "toss" rep points?
              Hans
              • Synthohol
                • Mar 2016
                • 5805
                Originally posted by Hansoon
                **OFF TOPIC**
                Hans
                at the bottom of posts above reply to thread there is a star and a triangle.
                the star gives you a choice to add or remove from that users rep along with a comment.
                the triangle reports posts for spam or whatever.
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4632
                  **OFF TOPIC**
                  Hans
                  Click on star at bottom left of post to leave a positive "reputation" point. You can also leave a negative red card for the spammers, etc.
                  Ha-ha Synthohol and me posted at same time. Great minds think alike!
                  • christian8220
                    • Jul 2020
                    • 53
                    How To Remove Konica Minolta C364e Transfer Belt #konica #printer #xerox - YouTube that shows how to remove the transfer belt. Another video Refurbishing Transfer Belt Assembly Bizhub C554e - A161R73311, A161R73300 - YouTube showed how to take it apart.
                    • tsbservice
                      Field tech
                      • 7981
                      Haha 🤣, nice work table. I hope they are well sealed, if not someone else may fart toner... like us.
                      • Synthohol
                        • Mar 2016
                        • 5805
                        i know that noise better than my own voice.
                        glad we could point you in the right direction.
