Bizhub C224e service bulletin
  • otphas
    • Aug 2019
    • 127
    Hi Guys ,
    do you know is it have any bulletin when your machine dont boot and stuck on pilars. I mean is it explanation what mean when the machine stuck on 2 or 4 or 5 pilars.
  • Synthohol
    Certified Konica Expert
    • 5905
    Re: Bizhub C224e service bulletin
    1. Machine starts boot cycle and verifies the firmware file.
    ○ Second Pillar:
    Machine memory Check (Standard onboard memory, DIMM, ASIC777,
    ASIC30 EFI, ASIC777 DS board) Scanner moves and initializes, energizes
    scan lights (e and 4 series)
    ○ Third Pillar
    Accesses SSD board
    ○ Fifth pillar
    Total boot process initializes
    • femaster
      • May 2011
      • 1526
      According to Knowledge Base Article: KBA00035556
      Which applies to: bizhub C258,bizhub 224e,bizhub 227,bizhub 284e,bizhub 287,bizhub 308,bizhub 364e,bizhub 368,bizhub 454e,bizhub 458,bizhub 458e,bizhub 554e,bizhub 558,bizhub 558e,bizhub 654,bizhub 654e,bizhub 658e,bizhub 754,bizhub 754e,bizhub 808,bizhub 958,bizhub C224,bizhub C224e,bizhub C227,bizhub C284e,bizhub C287,bizhub C308,bizhub C364,bizhub C364e,bizhub C368,bizhub C454,bizhub C454e,bizhub C458,bizhub C554,bizhub C554e,bizhub C558,bizhub C654,bizhub C654e,bizhub C658,bizhub C754,bizhub C754e,bizhub C759,MFX-3680N,MFX-4580N,MFX-C2260,MFX-C2280,MFX-C2280N,MFX-C2590,MFX-C2860,MFX-C2880,MFX-C2880N,MFX-C3090,MFX-C3680,MFX-C3680N,MFX-C3690,MFX-C4580N,MFX-C4590,MFX-C5580N,MFX-C5590
      Please see the attached PDF:
      The_Initial_Operation_during_MFP_start_Up.pdf
      For the Last 4 columns in the table, those apply when booting via the BOOT DIAGNOSTICS mode as seem in the yellow area at the top of the table.
