Looking for Installation Instructions for FS-534/RU-513 for C364e
  • yakatz
    • Mar 2021
    • 24
    I bought an old-stock finisher and used bridge for my C364e. The instructions that came with the finisher say to see the copier manual and the bridge didn't come with installation instructions. I am sure I could figure it out (and I have the service manual which shows disassembly and says to just to the reverse for assembly), but I was wondering if someone had the correct installation instructions and could share.
    Thank you.
  • femaster
    • May 2011
    • 1482
    Re: Looking for Installation Instructions for FS-534/RU-513 for C364e
    Here you go. When I tried the link, it opened and displayed the PDF in the OneDrive interface. You should see a "Download" button in the upper left of the screen, click that and save it to your local device to keep for future reference.
    Space is at a premium for me right now, so I will leave it up for a couple days only.
    Good luck with your install, hopefully they included the install brackets you need for your model copier.
    FS-534 Installation Instructions
    ** NOTE to anybody who stumbles upon this in the future: If the link no longer works, DO NOT PM ME asking for a working link or a copy!
    • yakatz
      • Mar 2021
      • 24
      Thank you, that was really helpful. I managed to get everything put together despite some missing pieces and it looks like I can hole punch, staple, and fold just fine.
      I found a few interesting things that I wasn't expecting and I wonder if anyone has input:
      1. My bridge came with the "newer?" version of the bracket - a single piece instead of two separate pieces. It seems like it fits together properly, so I am guessing there is nothing to worry about.
      2. My finisher and bridge did not come with this "gasket assy" (looks like it would have originally come with the machine, but I don't have it). Is this an issue?
      3. I also did not get the "sensor unit" with my parts, but when I took the cover off, there was already something plugged in there which could match what is in the drawings in the instructions. Would there be more than one kind of sensor that goes in that space?
      4. I am missing this bracket too. Any issues?
      5. My spring plate looks totally different than this - how do I turn it around?
      • rrrohan
        • Sep 2011
        • 1977
        1: I prefer the old brackets. made transport safer because they couldnt get bent
        2 and 4 and 5: I never bother with these
        3: im pretty sure thats only for telling copier to print reports out ontop of the relay unit. Ive run finishers without this sensor plenty of times without issue. even left it on refurbs that dont have the finisher anymore and its also been fine
        • femaster
          • May 2011
          • 1482
          1. The full bracket should work fine. We've used both the single and the dual piece mounts on those models, and both seem to work equally well.
          2. Have never used that, shouldn't be an issue.
          3. Not completely necessary. All this does is allow you to use the space about the relay unit as a third output tray. It will probably still show up as an output tray in the system and print driver, but without that piece the copier will log a jam if you attempt to use it as a tray.
          4. That piece is used to assist with grounding. Not strictly necessary as there is (or should be) grounding tabs on the finisher up near the area where relay unit connects to the finisher.
          5. I wouldn't even worry about turning it around. Without the piece in question 4, it isn't going to do anything anyway, and as I stated in 4, there should already be a ground near the relay connector.
          • Ziggy
            • Feb 2018
            • 693
            [ATTACH=CONFIG]58109[/ATTACH]
            [ATTACH=CONFIG]58110[/ATTACH]
            [ATTACH=CONFIG]58111[/ATTACH]
            [ATTACH=CONFIG]58112[/ATTACH][ATTACH=CONFIG]58113[/ATTACH]
            Number 4 is where the plate in number 5 hits machine
            on number 5 that is just a grounding bracket to turn it around take off screw holding it and flip it around so its facing the machine and reattach . but I've seen them run with no trouble without flipping
            If its working the way you have it put together I wouldn't worry about what you are missing
