C284 firmware error
  • FuserNoob
    Service Mgr, CISSP
    • Jul 2022
    • 162
    C284 firmware error
    Hi Folks,
    I have a bizhub c284 that I'm trying to update the firmware and have run into a snag.
    The current is Version 5 A1610Y0-F000-G00-72(00). I'm trying to get to Version 7 GR7-M0.
    The release notes for GR7 state that it requires G20-K8 to update.
    I tried the G20-K8 intermediate and got an error message, so I tried going straight to GR7-M0 with the following results:
    MFP CONTROLLER - download N.G.3 (last time I tried)
    ADF(DF-M) Download Completed. Check Sum 3904
    SCANNER Download Completed. Check Sum 969C
    PRINTER Download Completed.
    I tried loading GR7 again selecting only the MFP CONTROLLER and got the same error.
    The machine will now load all 5 pillars, but will not boot.
    Any thoughts?
    Thanks!!
  • copier tech
    • 8220
    Re: C284 firmware error
    Originally posted by FuserNoob
    Hi Folks,
    Any thoughts?
    Thanks!!
    Try updating the SSD there is a speartate file for this it is v.6.03. Then update with the latest firmware.
    • avecosat
      • Jun 2012
      • 305
      I update the 4 series non e with the GB3-M0 and I think it brings the update of the SSD to 6.03 included
      • FuserNoob
        Service Mgr, CISSP
        • Jul 2022
        • 162
        I did a C284 search in One Stop and didn't get a hit on GB3-M0 under either Base Firmware or Special Firmware
        • FuserNoob
          Service Mgr, CISSP
          • Jul 2022
          • 162
          any idea where i can find it? One Stop isn't exactly intuitive - THANKS
          • avecosat
            • Jun 2012
            • 305
            It's in KNOVA
            • femaster
              • May 2011
              • 1526
              Do you have an "e" or non-e model? I believe the special SSD firmware update only applied to the xx4e models.
              • FuserNoob
                Service Mgr, CISSP
                • Jul 2022
                • 162
                This one is a non-e C284, as in the description
                • tsbservice
                  Field tech
                  • 8064
                  Try it with HDD disconnected and select only MFP as you already tried. And maybe try another FW version.
                  If no go, I personally wouldn't hesitate to use reset tool as you already have a brick.
                  • FuserNoob
                    Service Mgr, CISSP
                    • Jul 2022
                    • 162
                    OK, Apparently this was a reading comprehension test... The G20-K8 that I tried to install on my NON e C284 is the intermediate step for C224e, C284e, C364e models...D'OH!
                    • FuserNoob
                      Service Mgr, CISSP
                      • Jul 2022
                      • 162
                      OK...Update (for those who are interested)
                      I reloaded G00-72 (the version it had initially) on the MFP only and it booted normally.
                      Then I tried reloading GR7-M0. Again the printer, scanner and ADF took, but the MFP was NG.
                      On reboot, it gets to the 5th pillar and throws and this error:
                      Error.
                      This is invalid External Memory.
                      Please make sure the External Memory.
                      • femaster
                        • May 2011
                        • 1526
                        I suspected, but it's surprising how many times people forget to add the trailing the letter on the model, which leads others to provide inaccurate or incompatible advice.
                        As I stated earlier, I'm 99% sure the SSD firmware only applied to the xx4e-models. I can easily find the SSD Tool for the C284e, but nothing under the C284.
                        • FuserNoob
                          Service Mgr, CISSP
                          • Jul 2022
                          • 162
                          I was able to get it working with the firmware version it had to begin with - G00-72
                          I ran an initialization, reinstalled the hard drive and doing a physical format now
                          • femaster
                            • May 2011
                            • 1526
                            Looking through the KM website, it seems like they have removed all the in between versions of firmware for the C284, with only the initial release (G00-72) and a couple of the more recent Gxx-M0 versions available.
                            I looked through our server and we have saved copies of GA2-K6 and GB0-K8, then a couple versions of M0. If you are interested in trying either of those 2 older versions as an in between upgrade to see if that works for you, I can try and figure out a way to get them to you.
                            • strider5555
                              • Jun 2008
                              • 96
                              Roll it back to G00-72, then first load GB0-A9 version up firmware, then proceed with GR7-M0. Make sure to read the GB0-A9 firmware pdf, there are important steps to follow. Warning, the last time i did this it wiped the machine, counters were zeroed out, but it did the recovery and all settings came back. I did have to set the IP address again as well.
