C284 firmware error
Re: C284 firmware error
Roll it back to G00-72, then first load GB0-A9 version up firmware, then proceed with GR7-M0. Make sure to read the GB0-A9 firmware pdf, there are important steps to follow. Warning, the last time i did this it wiped the machine, counters were zeroed out, but it did the recovery and all settings came back. I did have to set the IP address again as well.Comment
Not sure what else to try. I never had any issues other than what I mentioned. Try without the HDD attached, check that the machine type select information is correct, possibly format the SSD. Clear all data possibly, or even a trouble reset. Not sure what else to try. Maybe someone else will have more suggestions.Comment
did you "Before Updating the machine firmware to GB0-A9a. Set Software Switch 25 to HEX 20.b. Install GB0-A9 firmware. "
just checking, please check the machine and type selection when booting to a firmware stickWe know a thing or two because we've seen a thing or two.
The medication helps though...Comment
I did set the software switch, I did not check the machine type.Comment
Is there another intermediate FW I can try to get from G00-72 to GP0-A9 and then upgrade to GR7-M0?Comment
the firmware cheats the machine into some features of the E models but i dont think it is able to continue upgrading using newer E versions. those are discontinued and they are not gonna keep updating a dead possum in a tuxedo. that was a kinda hold me over until they didnt have to support it anymore.We know a thing or two because we've seen a thing or two.
