C284 firmware error
  • FuserNoob
    Service Mgr, CISSP
    • Jul 2022
    • 143
    Re: C284 firmware error
    Originally posted by femaster
    Looking through the KM website, it seems like they have removed all the in between versions of firmware for the C284, with only the initial release (G00-72) and a couple of the more recent Gxx-M0 versions available.
    I looked through our server and we have saved copies of GA2-K6 and GB0-K8, then a couple versions of M0. If you are interested in trying either of those 2 older versions as an in between upgrade to see if that works for you, I can try and figure out a way to get them to you.
    Check your PMs - thanks
    • FuserNoob
      Service Mgr, CISSP
      • Jul 2022
      • 143
      Originally posted by strider5555
      Roll it back to G00-72, then first load GB0-A9 version up firmware, then proceed with GR7-M0. Make sure to read the GB0-A9 firmware pdf, there are important steps to follow. Warning, the last time i did this it wiped the machine, counters were zeroed out, but it did the recovery and all settings came back. I did have to set the IP address again as well.
      I did the rollback to G00-72, but GB0-A9 is not on One Stop
      • strider5555
        • Jun 2008
        • 96
        It should be listed under special firmware.
        • strider5555
          • Jun 2008
          • 96
          #19
          This may help. Version Up firmware for MIF devices.pdf
          • FuserNoob
            Service Mgr, CISSP
            • Jul 2022
            • 143
            #20
            This may help. [ATTACH]58168[/ATTACH]
            AWESOME! THANKS!!
            • FuserNoob
              Service Mgr, CISSP
              • Jul 2022
              • 143
              #21
              got it - THANKS!
              • FuserNoob
                Service Mgr, CISSP
                • Jul 2022
                • 143
                #22
                OK...so I tried loading GB0-A9 and got the same MFP N.G.3 result
                • strider5555
                  • Jun 2008
                  • 96
                  #23
                  Not sure what else to try. I never had any issues other than what I mentioned. Try without the HDD attached, check that the machine type select information is correct, possibly format the SSD. Clear all data possibly, or even a trouble reset. Not sure what else to try. Maybe someone else will have more suggestions.
                  • Synthohol
                    Certified Konica Expert
                    • Mar 2016
                    • 5784
                    #24
                    did you "Before Updating the machine firmware to GB0-A9a. Set Software Switch 25 to HEX 20.b. Install GB0-A9 firmware. "
                    just checking, please check the machine and type selection when booting to a firmware stick
                    • FuserNoob
                      Service Mgr, CISSP
                      • Jul 2022
                      • 143
                      #25
                      I did set the software switch, I did not check the machine type.
                      • Synthohol
                        • Mar 2016
                        • 5784
                        #26
                        i only suggest it because MFP wont load if the wrong M&Type are displayed
                        • FuserNoob
                          Service Mgr, CISSP
                          • Jul 2022
                          • 143
                          #27
                          OK, tried it again, verified M&T and software switch and still got MFP M.G.3
                          Is there another intermediate FW I can try to get from G00-72 to GP0-A9 and then upgrade to GR7-M0?
                          • Synthohol
                            • Mar 2016
                            • 5784
                            #28
                            the firmware cheats the machine into some features of the E models but i dont think it is able to continue upgrading using newer E versions. those are discontinued and they are not gonna keep updating a dead possum in a tuxedo. that was a kinda hold me over until they didnt have to support it anymore.
                            • Abiort
                              • Nov 2023
                              • 1
                              #29
                              I'm facing the same problem on a Bizhub c364e, did you have a solution?
                              • Synthohol
                                • Mar 2016
                                • 5784
                                #30
                                yours is an E model, totally different.
                                you are welcome to start your own thread
