C2070/C3070 A50UR72V00 Toner Conveyance Assy
  • methogod
    • Dec 2008
    • 930
    anyone have one of these in stock that will sell me one...
    USED is ok too, BLACK if used is ok too, but ill clean any color and make it work....
    being told 2-3 weeks SPECIAL ORDER....
  • wjurls
    • Feb 2017
    • 507
    Re: C2070/C3070 A50UR72V00 Toner Conveyance Assy
    What happened to it that prompts it to be replaced and not repaired? Unfortunately I just recently sent a parts C1060 off to scrap.
    I may have another customer ready to retire one as well but that might be a spell yet.
    • methogod
      • Dec 2008
      • 930
      Low density on Black C 2454
      DV units and DV were at 1.7M
      replaced all 4 after a long run of light coverage.
      confirmed its not adding toner to K (BLACK)
      Flags toner is present in sub hopper, i see it adding toner to CYM, density over 8% in the revert screen, whereas BLACK is at 1.1% and no toner is being added.
      I am having a hard time confirming the part number from the book to even order it.
      anyone want to help?
        • 22995
        This is what I'm showing in the C3070 manual:
        A9VER71700 Toner Conveyance Assy
        A9VER72000 Toner Supply Unit
        The C1060 manual lists:
        I haven't had them apart, so I can't tell you about differences, but KM is pretty consistent about keeping the part number the same if the part is the same. That's a round-about way of saying that there are probably some differences.
        The C3070 manual lists separate part numbers for the gears and motor, which do not show up in the C1060 manual.
        • methogod
          • Dec 2008
          • 930
          Told today that part number has been superseeded by
          A50UR72V00 REPLACED BY A50UR72V12
          $467.71
          pulling it tonight, know more shortly.
          in the market for a C6100 if anyone has one coming off service. Under 4M, full boat (Prefer SD506 and IQ).
          • wjurls
            • Feb 2017
            • 507
            Could it also be Clutch 13? p/n A00FM20000 "Clutch"
            Each color has it's own clutch to drive the bottle.
            • wjurls
              • Feb 2017
              • 507
              To a point, yes, but they have a lot of parts that are pretty much identical, and are a direct fit, with different part numbers. For example the "Toner Guide Brush" for the Pro 1051/1200 is part number A0G6R73011 and is discontinued. The exact same part for the 1052/1250 has a mildly different texture to the brush but otherwise is a direct fit to the 1051 and is part number A4EUR70K00. It's also much cheaper. Same deal with developing units and cleaner units, LPH, etc.
              • methogod
                • Dec 2008
                • 930
                I have control of each toner bottle, eliminates the clutch and m15 motor. Replacing black sub hopper, and the printer control board if still not fixed after.
                toner hoppers are deep, almost cheaper to grab parts machine.
