Re: Bizhub c250i magenta stripes and grainy color
Last week this customer called me and said he had yellow streaks on the print. In the morning everything was still good and they replaced the yellow toner because it was empty.
When I was on site I could see how the charging roller and the cleaning roller underneath were full of yellow toner. The pattern was like the magenta earlyer. I then put this drum in the magenta slot and was expecting to see a magenta stripes(with 6-7cm) but that wasn't the case.
Only after 15 prints did a few thin stripes become visible.
The drum values were also (still) too high. That's why I replaced the yellow drum. But even with the new drum the print was still not okay... not even after 20 A3 prints for cleaning. Stabilyzer and Gradation with no effects.
Photo of print with swapped drum yellow/magenta. After replacing yellow drum the yellow pattern was still there.
During my search I discovered a few fine lines in cyan full pattern and decided to swap the cyan drum too. And then, like a miracle, this yellow pattern disappeared immediately.
Now all the drums have been replaced from the factory, last year the magenta and now the Y+C which had a life value of 59%.
That grain in the print is still present.
The next day I had a call from another customer, yellow toner was replaced and about 2 weeks later there was a slight yellow background on the entire paper. But more about that in the other thread for background. (really interesting information)
Of corse i have only genuine original Toner.
