Konica C3320i Not recieving IP address on network
  • jonbonse
    • Jun 2009
    • 734
    Hi all
    I am hopeful someone can assist with the below....already starting to regret getting the c3320i!!
    I just installed a C3320i but it wont receive an IP address from the customers network.... I have set it to DHCP and also tried a known free static IP address but still cant connect........
    This machine was setup on our network before taking to the customers where it received the IP address from our network.. They also have a C308 which we installed a while back and that is fine...I connected the c3320i to the same port the c308 was on but still not working with DHCP or Static IP.
    I have connected the C3320i via a crossover cable directly to my laptop and I can access the printers web page with no issues...I then connected my laptop to their network with a normal ethernet cable and received an IP address instantly and I can access the internet on their network this way...so I cancelled out MAC filtering as my laptop received the IP address..
    I have reset the network via the web interface, cycled power, but still will not receive an IP address...
    I have connected it directly to customers switch - nope!
    The firmware level is 'GC2 N4'.
    I have turned off IPV6...no difference...
    The only way I could connect via the customers network was by installing a Netgear wifi extender with a built in 5 port switch. I connected the wifi extender to the customers wifi and then ethernet cable to printer and is working fine....weird!
    The wifi extender is just a workaround so need to get it sorted without it..
    I am crossing my fingers ppl!
    TIA
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5804
    Re: Konica C3320i Not recieving IP address on network
    try locking down the speed to 100mbs duplex on the copier. ive seen copiers argue with switches over an acceptable speed denying the connection to begin with.
    most switches are auto speed detect. so is the damn copier. ususally one gives up and stops trying to connect.
    you can even try 10mbs duplex.
    ive seen it at least a dozen times. lock in a static IP and lock down the speed.
    thats my .02
    good luck.
    • jonbonse
      • Jun 2009
      • 734
      thats my .02
      good luck.
      Thanks buddy, do you recall where the speed setting is? Admin mode?
      • Synthohol
        • Mar 2016
        • 5804
        yes.
        network, detail setting i think?
        do you need the service manual?
        • jonbonse
          • Jun 2009
          • 734
          yes.
          No I already have it bud.
          • Synthohol
            • Mar 2016
            • 5804
            OMFG i just looked at the manual, is this machine a joke?
            there does not seem to be a setting for speed on that thing.
            i thought it also had wireless built in. does it?
            • tsbservice
              Field tech
              • 7977
              Select [Network] - [TCP/IP Setting] - [TCP/IP Setting1] in administrator mode of Web Connection (or in [Utility] - [Administrator] of this machine), and configure the following settings.
              [TCP/IP] When enabling TCP/IP, set this option to ON (default: ON).
              [Network Speed] Select the network speed according to your environment (default: [Auto (10M/100M/1Gbps)]).
              • jonbonse
                • Jun 2009
                • 734
                No wireless im afraid
                So I guess that means scrap the speed setting !
                • jonbonse
                  • Jun 2009
                  • 734
                  Thanks!
                  I will give this a go tomorrow
                  • tsbservice
                    Field tech
                    • 7977
                    If network speed change doesn't help go to service mode system 1 and initialize network.
                    P.S. avoid colour A4 KM any time you can
                    • jonbonse
                      • Jun 2009
                      • 734
                      Which A4 colour MFP. would you recommend?
                      • tsbservice
                        Field tech
                        • 7977
                        Originally posted by jonbonse
                        Your question is out of subject.
                        We deal only with Brother and KM so depending on clients we pick the right not necessarily the best.
                          • 22999
                          Does this sound familiar? We've come across this on a couple of the Lexmark rebadged as Konicas. After weeks of fretting over it, these new machines were eventually replaced with Lexmark badged devices of the exact same build, which worked just fine (??? no I don't have any explanation):
                          bizhub 4052, 4752
                          Won't scan, print or access user boxes while connected to the network. MFP locks up. When Scan is pressed goes to time clock (forever). Will not print from the network or even internal reports, until the network cable is disconnected.
                          Network traffic causes the MFP to lock up. Affects only all (4) bizhub 4052's on this network. Detail codes: (8) 0X1FFF, (5) 0X9CE2, (2) 0X4002, (1) 0X201A, (1) 0X2017, (2) 0X2008, (1) 0X2015, (1) 0X076C.
                          Refer this issue to endusers IT.
                          • jonbonse
                            • Jun 2009
                            • 734
                            Thank you all!
                            I changed the speed and all good now!
                            • olivenoire
                              • May 2021
                              • 39
                              Thank you for question and reply. It helps me connect again my C3320i. For unknow reason, I had to switch to full 100 instead of previously fontionnal AUto.
