DI-850 front door open intermittent
  • sunsetoutpost
    • Nov 2009
    • 54
    PS17, 24 & 25 I/O checks out in Mode 47, but I see no change in MS1, MS2 (25-04)when error occurs (stays high). Re-seated connectors on switches and DCPS2, switches test OK & 24V at FT1, FT2 of DCPS2. Chasing a ghost.
    If it happens again, I'll change out DCPS2.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4654
    Re: DI-850 front door open intermittent
    I'm sure you realize with the "DI" series being 20+ yrs old that strange issues could be many things. Been a long time since I worked on a DI model but if the front door interlock is a Cherry type switch just replace it. Although you might be on to something with the PS since those old models used interlocks to cut power, fuser, etc.
    • sunsetoutpost
      • Nov 2009
      • 54
      Caught it in the act Friday evening, 24V PS shut down. Replaced PS2 and all is right with the world.
      • Synthohol
        Certified Konica Expert
        • 5808
        cant believe you found a PSU for that one!
          • 23002
          Congratulations on catching it in the act. The old microswitch doorswitches typically switched 24vdc, often to the HVT, so you don't electrocute yourself. =^..^=
