Use a generic HID card reader for authentication
  • cateful
    • May 2023
    • 9
    [Misc] Use a generic HID card reader for authentication
    we have 10 c558s managed by PaperCut. according to the documentation all card readers with keyboard emulation are supported. so we went ahead and purchased 10 generic keyboard emulation card readers.
    It turned out the MFDs treat this kind of card reader as a keyboard (as expected), but since it isn't treated as an authentication device, papercut does not pick it up. Any idea how we can set a generic card reader as an authentication device? The reader works fine without a LDD, and apparently there is no driver written for this device.
  • kingarthur
    • 1389
    Re: Use a generic HID card reader for authentication
    which card reader are you using - not all card readers work on KM devices
    • cateful
      • May 2023
      • 9
      It's a a ZKTeco IC USB model
      Hardware ID: HID\VID_FFFF&PID_0035&REV_0001&MI_00
      On a computer it functions just like a regular keyboard where a card-swipe is the equivalent of typing out the card number and hit enter.
      • Woxner
        • Jul 2011
        • 854
        did you select device 2 and card in service mode stop 0 9
        • cateful
          • May 2023
          • 9
          if we do that, the mfd will complain that it cannot find an authentication device because the card reader is recognized as a USB keyboard.
          • Synthohol
            Certified Konica Expert
            • 5901
            have you installed the correctly configured LDD driver to the machine?
            i saw you said no LDD is loaded.
            from the 8 series and up we customize an LDD driver. i seem to remember a bulletin saying KM wont make them anymore and you have to program it yourself.
            i remember some app you type some info and it makes the tar file for you.
            if i remember more ill post it.
            • cateful
              • May 2023
              • 9
              Thank you! If you have the file I will definitely contribute.
              • Synthohol
                • 5901
                i sent you a PM, its for a 205H which is the only ones we use so i cannot guaranty anything but worth a try.
                tar file gets installed as is, dont unpack.
                • emujo2
                  • Mar 2017
                  • 1579
                  If you just plug the reader in and do not tell the machine what it is, it just identifies it as a keyboard..Confiigured like this it will never work for authentication..The machine needs to understand the reader is present (Service mode/Authentication card settings) and the LDD which gives the machine the proper VID/PID codes..This is where creating your own LDD with the KM tool might help. If you can get the Vendor ID and PID codes in device manager and program a new LDD with these codes it might work, this is assuming you are using KBW mode. E
                  • cateful
                    • May 2023
                    • 9
                    Yes this makes sense. Any idea where I can find this KM tool? Google searches return nothing.
                    • Synthohol
                      • 5901
                      isnt the tool pcprox?
                      this may help
                      ive only used rfideas readers.
                      • cateful
                        • May 2023
                        • 9
                        I have pcprox but it doesn't create the ICC_LDR.tar file. I can mess with the configuration but it does not let me generate a driver.
                        • tsbservice
                          Field tech
                          • 8062
                          Auth device tool advanced is maybe what you need although I'm not sure it will work with any type devices.
                          • Synthohol
                            • 5901
                            i sent you another PM.
                            i think you will like this one?
                            • Synthohol
                              • 5901
                              the LDD file you have is likely already been modified, you may need a raw one.
                              i lost my access to MKM so i can send you another one to try?
