Copitrak on Bizhub
  • kingarthur
    • 1405
    Copitrak on Bizhub
    Has anyone managed to get Embedded, or any Copitrak working on a Bizhub - Cheers
  • Synthohol
    Certified Konica Expert
    • 5958
    Re: Copitrak on Bizhub
    literally a thousand times, are you looking for pros and cons or merely instructions to setup?
    • kingarthur
      • 1405
      just want to know how to instal it on to a device, I know nothing about Copitrak
      • Synthohol
        • 5958
        its pretty easy to enable it and create a user\password list.
        once enabled you will need to either enable popup password printing or lock it in under printing defaults.
        also can configure if user can print in color or not.
        at whatever interval, the 'admin' can print out a list of users and their counts or retrieve via software or just view in a browser.
        you can enable print with or without a password.
        you can enable a 'public' user with limited features.
        would you like a service manual to get familiar with the screens/menus?
        [edit] its easier on the users to use Account track over authentication because you just need a single pin rather than user name and pin. [/edit]
