Bizhub 306i error C-D010
  • dacam20590
    • May 2019
    • 30
    i only see the micro sd card but i don't see hdd. what should i do to fix it?
  • Ziggy
    • Feb 2018
    • 711
    Re: Bizhub 306i error C-D010
    go to service mode , system 2 and change storage type from micro sd to storage board if thats what you have. We dont have the 306i in the USA market, but all of our machines similar is size use a storage board
    • tsbservice
      Field tech
      • 8003
      What your service manual is telling you? Probably format SD card, update firmware or replace it.
      We don't have that model but I believe SSD is an option.
      • dacam20590
        • May 2019
        • 30
        I have successfully fixed the error. Replace micro sd. I don't understand why this model uses micro sd.
        • tsbservice
          Field tech
          • 8003
          It's by specs.
          • allan
            RTFM!!
            • 5462
            Konica Minolta set out to make it as cheap as possible and they need somewhere to put data.
            Good job it works.
            Whatever
            • escalante
              • Sep 2018
              • 115
              Good morning. Please can you upload a photo of the microSD
              Enviado desde mi Infinix X693 mediante Tapatalk
              • Synthohol
                Certified Konica Expert
                • 5814
                storage board or microSD located on the CPU board assy.
                • escalante
                  • Sep 2018
                  • 115
                  Good night. I found this segment in a solutions guide. I hope it is very useful
                  • rrrohan
                    • Sep 2011
                    • 1977
                    my region doesnt used the SD it uses the NVME variant but i was wondering.
                    if i get a suspected dead storage board can i throw in a random micro SD and switch the storage type as a temp fix/to confirm its the storage board and not the base board or cpu board
                    • Synthohol
                      • 5814
                      that is exactly what id try.
                      make sure the firmware is for the SD card as well in case of a difference.
                      • tsbservice
                        Field tech
                        • 8003
                        Yes you can.
                        • rrrohan
                          • Sep 2011
                          • 1977
                          any downside to leaving them on SD assuming its a decent class 10 card? also whats the capacity minimum 128GB?
                          • tsbservice
                            Field tech
                            • 8003
                            Yes, check PM
                            • rrrohan
                              • Sep 2011
                              • 1977
                              its only 8GB? wow
