C300i bad image
  • suomi
    • Oct 2008
    • 152
    C300i bad image
    First E002 & new cpu board & everything OK..But print image is bad. Black print is OK.
    SKM_C36823060114240.pdf
    PH unit?? Memory board changed & tar reset done.
    Drums & belt OK
  • Mitch Barron
    • Mar 2013
    • 180
    Re: C300i bad image
    [ATTACH]58415[/ATTACH]
    Drums & belt OK
    What was the problem that you have to change CPU, before you change it print quality was good or it was the same as your posting.
    • suomi
      • Oct 2008
      • 152
      Re: C300i bad image
      The customer reported that first a bad picture, then an error code E002
      And the printer didn't turn on anymore
      • Mitch Barron
        • Mar 2013
        • 180
        Re: C300i bad image
        Ok but the print quality was good before that happens, if it was good, then maybe the CPU is bad so you need to try another CPU, that happened to me in a 300i, after I tried with another CPU it was all back to normal.
        • copytechtrouble
          • Nov 2020
          • 112
          Re: C300i bad image
          Drums & belt OK
          from looking at the image you've attached, you need to change the 3 colour drums. what's the colour count on the machine?
          • allan
            RTFM!!
            • 5462
            Re: C300i bad image
            Look again the defects are digital in nature. Looks like the laser data is slightly corrupt or the laser cable is wonky.
            I would look at ribbon cables.
            Whatever
            • Black Cloud
              • 176
              Re: C300i bad image
              I had a C360i with a similar symptom but it was black instead of colours. In my case replacing the Print Head (Laser) Unit was the solution. A bit difficult to tell from the sample due to scan distortion but do the lines extend to the edge of the page? Mine did. I would try reseating the Print Head connectors first.
              Net+ PDI+ @Remote
              • Gift
                • Mar 2011
                • 2459
                Re: C300i bad image
                Also check the HV voltages and try another set of C/M/Y drums - I think I've seen this before and we also went down the laser path since the image error looks kind of "digital" but we were wrong in our case.
                • cpyfixer
                  • Oct 2008
                  • 11
                  Re: C300i bad image
                  I've seen this effect on C458 when the laser gets dirty from operating in a dirty environment. Pulling the laser unit out and opening it up, cleaning the mirrors, lenses, and poligonal mirrors always resolved it for me.
                  • barber782
                    • Aug 2011
                    • 286
                    Re: C300i bad image
                    I'm thinking CPU board, either reseat or replace.
                    Had some really weird issues replacing to CPU board failures.
                    Also recommended by Tech Rep at KM
                    • Kenny
                      • Jun 2009
                      • 534
                      Re: C300i bad image
                      We have had some 'fuzzy' quality issues from replacing the drum unit chips just to bare in mind
                      • suomi
                        • Oct 2008
                        • 152
                        Re: C300i bad image
                        This is exactly what it was all about. New drums from the transport-damaged device and the picture is bad. And before this the device was mute and had to change the cpu assy
                        • tsbservice
                          Field tech
                          • 8059
                          Re: C300i bad image
                          Drums from transport damaged device won't reset drum counters even they are never used. You will need new drum chips for machine to recognise them as brand new and makes automatic adjustments accordingly.
                          • tsbservice
                            Field tech
                            • 8059
                            Re: C300i bad image
                            @copytechtrouble good catch
                            • suomi
                              • Oct 2008
                              • 152
                              Re: C300i bad image
                              Yes it is.
                              It's a shame that Konica prevents the use of used drums. It would be good if you could reset the drum counter in the same way as the toner bottles, belts and fusing units.
