forget to add the copy
  • ledid33
    • Jun 2023
    • 3
    [Misc] forget to add the copy
    Hello, we have a new Konica C450i MFP.
    The Konica technician forgot to add the copy on the MFP screen.
    Do you know how to add it?
    Thank you
  • Synthohol
    Certified Konica Expert
    • 5894
    Re: forget to add the copy
    huh? how is that possible?
    i mean there is a custom main screen where you enable the icons but having copy missing?
    that sounds like a real f-up.
    id call them back and scream.
    • techsxge
      • Jan 2022
      • 660
      Go to Web Panel -> Log in as Admin -> System Settings -> Customize Main Screen (Or something like that, but it is under System Settings)
      • tsbservice
        Field tech
        • 8053
        Can you post a picture of display?
        • Ziggy
          • Feb 2018
          • 802
          Very close Admin>System Settings> Main Menu Default Classic Style > from there you should be able to select an empty key and add Copy.
          Main Menu Default (Classic style)
          To display: >>View
          • [Utility]
            • [Administrator]
              • [System Settings]
                • [Main Menu Default (Classic style)]
          Configure shortcut keys that are displayed in the main menu of classic style.
          Select a shortcut key number, and specify the function to assign. [Assignment No. 1] to [Assignment No. 11] are assigned to the first screen of the main menu. These keys should be assigned to frequently used functions.
          [Function Name] Select a category of function to be assigned to a shortcut key.
          • [Not Set]: Do not create any shortcut key.
          • [Function]: Create a shortcut key to the main screen such as Copy mode or Scan/Fax mode.
          • [Copy Function Settings]: Create a shortcut key to the setting screen for the copy function.
          • [Scan/Fax Function Settings]: Create a shortcut key to the setting screen for scan/fax function.
          • [Copy Program]: Create a shortcut key to a copy program. This option is available when copy programs are registered on this machine.
          • [Scan/Fax Program]: Create a shortcut key to a scan/fax program. This option is available when scan/fax programs are registered on this machine.
          • [System User Box]: Create a shortcut key to the System User Box.
          • [Eco Function Settings]: Create a shortcut key to the Eco-related function.
          • [Widget Settings]: Create a shortcut key to the widget setting screen.
          • [Quick Security Setting]: Create a shortcut key to the simple security setting screen.
          • [QR Code Display]: Create a shortcut key to the QR code display screen.
          • [Address book]: Create a shortcut key to the address book.
          • ledid33
            • Jun 2023
            • 3
            Hello, Thank you very much for your prompt replies
            I'm not here to test it, so I'll see tomorrow.
            Thank you and have a nice day
            here in Lyon the weather is fine
            • techsxge
              • Jan 2022
              • 660
              To display: >>View
              • [Utility]
                • [Administrator]
                  • [System Settings]
              yes thank you, i translated it on the go from memory and a german set machine
              • ledid33
                • Jun 2023
                • 3
                Hello,
                here is my page Admin>System Settings> Main Menu Default Classic Style >
                I can select a theme but not change it
                • techsxge
                  • Jan 2022
                  • 660
                  Originally posted by ledid33
                  Hello,
                  [ATTACH=CONFIG]58500[/ATTACH]
                  Go to 000.000.000.000/wcd/a_environment_stdtopmenu.xml
                  • Ziggy
                    • Feb 2018
                    • 802
                    That is main menu display. Scroll down a little further and look for main menu default (classic style)
                    • tsbservice
                      Field tech
                      • 8053
                      • [Utility]
                        • [Administrator]
                          • [System Settings]
                      • techsxge
                        • Jan 2022
                        • 660
                        He does not want to change the style / wallpaper of the main menu. He wants to add/remove a button, which is located on the link i typed in.
                        • tsbservice
                          Field tech
                          • 8053
                          I think until we don't see the picture of machine screen it's unclear what exactly is going on.
                          • Ziggy
                            • Feb 2018
                            • 802
                            That's the Same thing I told him in my 1st post
