C258 custom boot screen
  • copyman
    Owner / Technician
    • Sep 2005
    • 4723
    How to remove the previous dealer custom boot screen? Know there is a boot converter app to customize but I want to change back to factory default. Not sure if this is were you change it but went to system 2 , 2nd page and looks like the customize screen tab is missing? Is there a soft switch to turn it on? Or is there another procedure to change boot screen back to factory default? Probably could find it in service manual, sorry for being lazy.
    Thanks in advance
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5849
      • 8174
      Re: C258 custom boot screen
      Thanks in advance
      You can also delete it from the trouble reset screen.
      Power on the device while holding down reset (yellow key) once at the trouble reset screen press delete.
