Konica Minolta bizhub press C 1070
  • Momiowilove
    • Sep 2019
    • 63
    Error C 2451 after we replace the developing unit and developer. The problem still occurs we do the toner revert multiple times but code still occurred can you help us in this problem thank you very much
  • Todd Glenn
    • May 2021
    • 22
    Re: Konica Minolta bizhub press C 1070
    Did you do the Toner Density Sensor Init., in the service mode, under drum peculiarity, first? Also, make sure the charger corona for the Y developer unit is installed fully, and not broken or damaged/ saturated with toner.
      • 23010
      Make sure that the primary transfer belt is properly tensioned. I've had one of the cables break that keep the belt tensioned. The belt tracks off center, and incorrectly reads the yellow density patch. =^..^=
      • wjurls
        • Feb 2017
        • 501
        Like Todd already mentioned, the toner density init must be done with new developer. A vacuum wasn't by chance used at all on the developing unit was it?
