c654 ADF white guide
  • Synaux
    • Mar 2012
    • 1224
    I feel somewhat silly asking this but what is the purpose of this guide?
    __10-24-2017 bizhubC654E_C754eServiceManual2.pdf it is the white strip on the bottom of the ADF with a foam backing.
    (For some reason I cannot upload a photo.)
    I recently had it fall off and jam into the feed path behind it on two machines. After removal, the unit seems to work just fine.
    They are cheap and I ordered some replacements...just curious.
  • Synthohol
    Certified Konica Expert
    • 5906
    Re: c654 ADF white guide
    usually when i've seen foam cushioning its to prevent chatter or vibrational noise.
    • Synaux
      • Mar 2012
      • 1224
      I don't necessarily disagree, but I finally got my phone to cooperate. It is a little difficult to tell but that area is recessed from the platen. *edit* the white strip/guide was originally on that foam strip
      • Woxner
        • Jul 2011
        • 854
        helps the ccd read the light intensity. kindof like the white roller on the newer feeders
        • allan
          RTFM!!
          • 5462
          Anyone had any issue removing it. I have been removing them for ages. If its causing some king of issue I am not aware of it.
          Same for the same kind of patch on the exit side of tray 2 on the C558 for instance. Does not seem to hurt.
          Whatever
          • Synaux
            • Mar 2012
            • 1224
            Unless someone says something I am going to cancel the order.
