C3300i boot up failure
  • jwai
    • May 2018
    • 504
    hello,
    one C3300i could not boot up with 25% bar, enter service mode( turned on with stop key)same result.
    will be defective of CPUB orSD card?
  • tsbservice
    Field tech
    • 7950
    Re: C3300i boot up failure
    SD card.
    • Ziggy
      • Feb 2018
      • 689
      Originally posted by jwai
      hello,
      I've seen both cause this problem. I would start with SD card since its cheaper. Just be sure once you try the SD card if it doesn't resolve the problem pull it out and put the original SD card in the new CPU.
      I highly recommend following the instructions in the latest manual when it comes to replacing board on any i-series
      • Digital
        • Feb 2021
        • 17
        Have you tried with a software update?
        I had similar problems with those models and i solved with that.
        • jwai
          • May 2018
          • 504
          I tried stop+main SW ON, screen displayed only 25% bar with black dot only.
          • tech51
            • 846
            Worth giving the recovery firmware a go first.
            • elmaligno
              Expert technician KM
              • Oct 2009
              • 301
              hello,
              Try recovery FW
              AAJT0Y0-F000-GXX-26.exe
              Field technician since 1994
              • mojorolla
                The Wolf
                • 2574
                Remove the SD card and attempted to do a firmware update with USB. If you can get to the firmware update screen, SD is probably bad.
                • jwai
                  • May 2018
                  • 504
                  SD card.
                  Could I buy OEM micro SD card ( 8GB or larger ) instead of genuine KM parts?
                  If it can, what procedures should be taken before installation?
                  • and
                    • Oct 2011
                    • 96
                    Thank's a lot mojorolla for this post.
                    In my case recovery tool not start. Removed the SD i can do firmware update and use recovery tool to check CPU was good.
