INEO +250I BACKGROUND
  • cla65
    • Jul 2023
    • 17
    hi all, I have cyan and sometimes yellow background problems.
    the color developing units have been running for 3600 minutes, the drums are
    at 20% of use, the toner is original.ATDC value 6.77
    doing the stabilization and gradation adjust it improves but after two days the problem returns.
    I tried to edit image backround adj, raising the values,
    the situation stabilized for a few days and then came back.
    the total counter is 60,400 of which 27,000 in colour, firmware F00-G00-Q6
    Do you have any suggestions? Thank you
  • GIUBOSS
    • 1436
    Re: INEO +250I BACKGROUND
    Probable false contact on the imaging units, you have cleaned the id sensors, initialize and stabilize.
    C250 black background
    Bizhub C250 With Yellow Background - Changed IU & Laser
    • cla65
      • Jul 2023
      • 17
      Thanks, I'll check the contact details of the developer units,
      I had extracted them all from the machine to check the integrity of the mylars,
      I haven't noticed anything out of the ordinary.
      Thanks again
      • tsbservice
        Field tech
        • 8020
        Check and report TCRs in service mode, should be around 7%
        • cla65
          • Jul 2023
          • 17
          +250i .jpg hello, the values are correct, I attach photos
          • tsbservice
            Field tech
            • 8020
            Originally posted by cla65
            [ATTACH=CONFIG]59005[/ATTACH] hello, the values are correct, I attach photos
            Yes readings are good, however fusing temperature is very low. Do you have poor fusing on solid colours? Do state confirmation and make cmyk halftones at 30 and 255 for us to see them.
            • Synthohol
              Certified Konica Expert
              • 5847
              i think the fuser temp is only accurate when you hit start on that screen, then it gives live action readings making a printout page.
              • tsbservice
                Field tech
                • 8020
                Good to know Synt never tried printout from that screen.
                • Synthohol
                  • 5847
                  yeah, when the screen is idle its kind of arbitrary readings but when you hit start you see the fuser temp go up and the live real atdc readings etc...
                  • tsbservice
                    Field tech
                    • 8020
                    Good lord thanks 😊
                    Going to put that on my belt but it's already heavy enough 🤣
                    • cla65
                      • Jul 2023
                      • 17
                      below the halftone prints with density 255 and 30
                      plus two internal prints first with magenta spots
                      and after initialization and stabilization of good quality, thank you
                      • tsbservice
                        Field tech
                        • 8020
                        Check ribon cables to the laser or laser itself(PH unit) it may be deffective.
                        • occus
                          • 337
                          I had a +250i where I had a cyan background. Any tests and attempts brought no solution except to exchange the cyan developing unit.
                          • cla65
                            • Jul 2023
                            • 17
                            Hi, I spoke to a kmi specialist and he suggested I replace the temp sensor.
                            I will try this solution and let you know. now the customer is on vacation.
                            Thank you
                            • tsbservice
                              Field tech
                              • 8020
                              Thank you
                              So what are temperature/humidity readings atm?
