C554e jam code 30-03
  • copyman
    Owner / Technician
    • Sep 2005
    • 4723
    I've read the bulletin about this code and other posts about this code. I replaced CL8 exit clutch and it was good for awhile now machine is jamming again with same 30-03 code. Customer left tray 1 & 2 empty and machine is working good from tray 3 & 4. Any idea why jams with 30-03 code would only happen from top 2 trays?
    Any help appreciated?
    Thanks in advance
  • tsbservice
    Field tech
    • 8020
    Re: C554e jam code 30-03
    Sounds like registration section bushings may be gummed up, paper hits registration slightly different when coming from upper trays. I would get one from working shop machine and try it.
      • 23009
      Not specific to trays #1 & #2 ... but I have seen J30-03 jams as a result of:
      *"mustache" defect: piercing of the primary transfer belt
      *fuser roller bearings siezing, and the consequent squealing and rust.
      *fuser jammed up with three accordian jams the enduser makes no attempt to remove.
      *very heavy fill images
      *heavy toner buildup on the fuser inner exit guide.
      *defective PS3 (A108 M501 00). Replacement sensor looks different, but works (type "SG").
      This last one is extremely unusual, and happened twice on the same machine, a year apart. It was in a school main office with a whole wall of 8' tall glass windows along the south wall. In the early morning it was so blindingly bright in that room, I initially concluded that the sunlight was somehow making it into photointerrupter PS3's receiver. I was wrong, but the intermittent nature of the problem made it very difficult to diagnose. =^..^=
      • Toxic
        • 698
        From my expirience in 90% of cases problem is *very heavy fill images in combination with small margin on the leading edge of paper.
        • allan
          RTFM!!
          • 5462
          +1. Use to strip out the roller and clean out the bushings. Now I use a can of plastic and rubber friendly electronic cleaner and flush the gunk out in place. Even the PS sensor gets flushed out with it.
          Whatever
