Bizhub C250i boot stuck at 25%
  • copier tech
    • 8236
    [Misc] Bizhub C250i boot stuck at 25%
    Hi all,
    This device was stuck on the boot screen at 25%.
    I have read a few bulletins on this issue & it usually requires ether the storage or CPU boards replacing.
    In my case I updated the device with the latest firmware (G00-Q8) it updated fine but booted up with a completely white screen, it restarted again to a white screen after 3rd
  • tsbservice
    Field tech
    • 8076
    Re: Bizhub C250i boot stuck at 25%
    You are lucky man to not replace anything yet. Never seen this particular situation before but those SSDs and CPUs are rather fragile or software/firmware depending. Fingers crossed 🍀🤞
    • tmmdmmm
      • Apr 2021
      • 173
      I asked one of my old tech buddies the other day if there was any update to this since I retired, doesn't look like it.
      Most of these CPU and SB issues were software related IMO, so if he got it back up and running he should have no issues going forward, especially if he gets up to current FW
      • rrrohan
        • Sep 2011
        • 1977
        Few times I have had this it was the AA2JM72702 Storage Board
        Especially if it was previously running on the old style longer sized one
        • Ziggy
          • Feb 2018
          • 814
          Hi all,
          [ATTACH=CONFIG]59159[/ATTACH]
          [ATTACH=CONFIG]59160[/ATTACH]
          [ATTACH=CONFIG]59161[/ATTACH]
          [ATTACH=CONFIG]59162[/ATTACH]
          There is a diagnostic tool that Konica just update a couple weeks ago that can tell you which board is bad. see attached
          • Gift
            • Mar 2011
            • 2459
            Thanks for the updated bulletin, wasn't aware of any updates in this matter but luckily I had no case since at least 6 month.
