Bizhub C364e external counter
  • otphas
    • Aug 2019
    • 127
    Hi all ,
    where i can find info how to remove external counter from C364e? I just open front door locate the counter and remove it connect 2 wires to short contact, but the green button flashing red and machine cant enter in ready mode? Is it have any Dipsw to disable the external counter?
  • Synthohol
    Certified Konica Expert
    • 5905
    Re: Bizhub C364e external counter
    dont ever remove stuff that came from factory.
    undo what you did and leave it alone.
    you do mean the copiers odometer right?
    • copyman
      Owner / Technician
      • Sep 2005
      • 4785
      Originally posted by otphas
      Hi all ,
      Are the mechanical counter wires suppose to be shorted if not used?
      Was it at a place where they sold copies? If so machine may also have billing set. Go into service mode, then "stop", "9". Once in the billing section look under management function choice, etc. to see if something to turn off.
      • otphas
        • Aug 2019
        • 127
        Yes , odometer, all other customers machine have only software counter and he want to remove the external one from this machine too.
        • Synthohol
          • 5905
          just stop. there is no reason to remove it. the machine will not work without it attached.
          that was stupid!!
          sounds sneaky and unethical to me.
          next time just hide it with black tape.
          duh.
          • femaster
            • May 2011
            • 1526
            I'd advise you to just cover it with black tape to hide it, as Synthohol has pointed out already.
            There was a change made during the production of the 4e-series of machines. Early ones came with the physical counter, later ones had eliminated it. If it came with the copier from the factory, it must remain in the copier or the copier will cease to function.
            If you are determined to remove it, you will need to order a part which has probably been discontinued. I'm not going to make it easy on you, as your reasons for it's removal sound very sketchy to me. If it's that important to you, you will do the footwork on your own to discover what needs to be done to accomplish that. The only hint you will get from me is that you will find the answer you seek in Parts Bulletin #9285 on the US MyKonicaMinolta website. I'm not sure if bulletin numbers are the same in all parts of the world, so the bulletin number may vary in your region.
            • otphas
              • Aug 2019
              • 127
              Cant find bulletin with same number in infohub EU.
              • Synthohol
                • 5905
                9285
