Konica c284e vs c280 color difference
  • wynter17
    • Mar 2019
    • 33
    Hello,
    We just replaced our old c280 with a refurbished c284e,the seller says that if we eant a better quality print we have to buy a new printer,but how is it possible that the old one is a lot better than the 284e,the black seems so washed.
    On the left is the c284e and on the right c280.
    Sent from my SM-S901B using Tapatalk
  • Synthohol
    Certified Konica Expert
    • 5805
    Re: Konica c284e vs c280 color difference
    the 284 looks like the driver is using process black without black overprint.
    im sure in the driver settings this can be much improved upon as well as a fresh set of gradation adjustments.
    the 280 print setting looks like pure black is used and possibly black overprint for even more richness.
    • wynter17
      • Mar 2019
      • 33
      I did a set of gradiation adjusments,will try with the ps driver since only that has the black overprint option available.
      Thanks!
      • copyman
        Owner / Technician
        • Sep 2005
        • 4632
        Keep in mind you are dealing with "business" color. The only way to get better quality results from a Kon/Min is if you add the optional Fiery print controller.
        Yes it's possible for a prior model to have better quality. But there are many other factors, aftermarket toners, life of consumables like Trans belt, Fuser, etc etc
        The Kon/Min color quality has gotten worse over the years. Some of the best color I remember from Kon/Min was the old CF3102 model. Quality downhill ever since.....
        • wynter17
          • Mar 2019
          • 33
          You were right,i tried the ps driver with black overprint and some settings for image printing and the quality is much better,thank you!
          • Gift
            • Mar 2011
            • 2458
            you need just more "black magic" cards to improve the black
            • tsbservice
              Field tech
              • 7981
              There are tons of reasons he has been and is Certified Konica Expert. Personally I would love work together with him anytime on anything 😉
              @Synthohol
              • Synthohol
                • 5805
                so ive been out of work 2 weeks short of a year but coming here and scratching my head for folks and helping the best way i can makes my 25 year career all worth it and looking forward to getting back at it after i have my neck surgery but in the meantime all the folks that expressed great thanks for my advice whether in PM or out here in the open forums i from the bottom of my heart really appreciate your kind words and keeping me thinking and sharp so i dont go stale and stay interested in this field and come back to work once surgery and physical therapy are done, hopefully early 2024.
                thanks tb and all you guys!! (and the occasional Femme-Tech)
                • copier tech
                  • 8132
                  Hello,
                  The C284e should have a very similar print quality to the old C280 if not better.
                  But as the device is not new do you know the drum life or if the device has genuine toner installed?
                  The best way to approach this is first print off the gradation test patterns in service mode & see how they look, especially the back.
                  Also worth checking toner save is set to off.
                  To display: [Utility][User Settings][Printer Settings][Basic Settings][Toner Save]
                  Select this check box to reduce the printing density in order to reduce the amount of toner consumed.
                  [OFF] is specified by default.
                  • tsbservice
                    Field tech
                    • 7981
                    Already solved but thanks for trying(especially the back) 😂
