Konica Minolta c454 coping / scanning issue
  • Kenny
    • Jun 2009
    • 536
  • Gaffers01
    • May 2011
    • 335
    Re: Konica Minolta c454 coping / scanning issue
    Samples ?
      • 15005
      Through DF or off glass?
      • tsbservice
        Field tech
        • 8064
        Bent scanner bed I guess...
        • copyman
          Owner / Technician
          • Sep 2005
          • 4785
          Definitely need more information to help you. One thing that comes to mind is if the A4 paper is being fed short edge first it could be missing a defect on edge of drum, trans belt, fuser, etc.
          • Kenny
            • Jun 2009
            • 536
            On both the glass and thought the ADF
            • Synthohol
              Certified Konica Expert
              • 5905
              while applying good upward pressure to the front left corner of the scanner try making another copy.
              some users like to think the scanner is a good place to put a whole case of paper on while filling the trays.
              • Synaux
                • Mar 2012
                • 1224
                Originally posted by Kenny
                Hi Guys,
                It puts a burnt mark on one edge of the paper,
                What is a burnt mark?
                Upload photo/scan of the issue.
                • the_teck
                  • Dec 2015
                  • 27
                  Bent scaner bed. Remove covers from left side of scaner (white cover), remove left side cover (T shape cover, black, 3 screws, it's the vertical one in the back, left side of machine). Under there you will find some screws (white) that hold the flatbed. Rise front corner of scaner (the one not supported by anything) till horizontal (use a level if you want to be accurate, check levelness of machine and adjust scaner accordingly). When horizontal, tighten the screws mentioned. Check copy. If still needed, in front of camera you have a screw msrked with red paint. Turn it one way a quarter turn. Try to remember how mich you turned and original position. Try copying. If worse, go the opposite way a quarter turn from original position. From here you will have an idea. Do not turn that screw more than a quarter as it will be difficult to return to original position (it's a very precise one).
                  LE: I assume you allready cleaned the mirrors and lenses.
                  • avecosat
                    • Jun 2012
                    • 305
                    I had something similar on a C364e, it was like a burn in a corner only in copy and scan. I had to change the lens and adjust the mirrors.
