Bizhub C658 showing 0.00% TCR Density for magenta
  • JasonSBE
    • Apr 2014
    • 183
    C458, not C658. Made a mistake when writing the title. Probably the same components, but wanted to clarify.
    Hey all, I've tried the developer, the FRB, and the high voltage board. Image quality is great, but the machine detects 0.0 for magenta and so of course it codes out after 25 pages or so. I don't want to run this machine too much until it registers right. Any other parts besides the MFP board that anyone can think of?
  • copier tech
    • 8107
    Re: Bizhub C658 showing 0.00% TCR Density for magenta
    Have you fitted a new magenta developer unit ?
    • copyman
      Owner / Technician
      • Sep 2005
      • 4550
      What about the drum? I always replace the drum & add some aftermarket developer, then manually add toner in service mode until around 6%.
      You covered a lot already. But you should of seen some type of change with new developer unit or even swapping from another machine.
      How about initializing machine?
      Only thing I can think of is MFP board if all else fails.
      • rrrohan
        • Sep 2011
        • 1977
        • tsbservice
          Field tech
          • 7928
          +1 for toner hopper
          • copyman
            Owner / Technician
            • Sep 2005
            • 4550
            OP said they replaced the developer and still at 0%. If new developer is installed the level history would change even if toner hopper was empty.
            • tsbservice
              Field tech
              • 7928
              Not necessarily. He said he replaced "developer" and we don't know what exactly he's replaced, powder, second hand unit won't reset TCR at all only brand new unit or chip.
              • kingarthur
                • 1305
                I had exactly the same problem, new DV units, new toner hoppers, toner motors, as it was happening on 2 colours, FRCB, I was ready to sell them a new machine, when I tried the expansion board, EXCB, p/no A79JH00500, couldn't believe it when it worked - been working for a year now
                • JasonSBE
                  • Apr 2014
                  • 183
                  Sorry, let me clarify. It was the developer unit, not recharging the one that was in the machine.
                  • JasonSBE
                    • Apr 2014
                    • 183
                    Thank you for the pointer. I'm going to look into it.
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4550
                      Thanks for the update. That is how I read your post. Since level didn't change makes me think a board for sure.
                      This is a strange one. Please let us know what it turns out to be.
                      • copyman
                        Owner / Technician
                        • Sep 2005
                        • 4550
                        Many times I've swapped "used" dev units between machines and was able to get levels back to 6+ %
                        • igor.sanfilip
                          • Mar 2015
                          • 11
                          HI,
                          try to disconnect and to reconnect all connectors on printer control board, worked for me on C220 when Y-TCR was sometimes 8% but mostly 0%.
                          • mitchl
                            • Apr 2007
                            • 501
                            KM weirdness at its best. I have a BHC658 that just refuses to add toner to itself when the TCR gets low. Yes you can manually tone it up to 6.5%, run 200 copies and its down in the 2% or lower range. New DV unit, new drum but the problem persists. Any ideas?
