printer b 3602p asking for PIN for settings menu
  • igor.sanfilip
    • Mar 2015
    • 11
    I've got a b3602p with locked settings menu, asking for PIN for device settings, network settings...
    Couldn't find anything in service manual or user manual.
    What am I missing?
  • Ziggy
    • Feb 2018
    • 780
    Re: printer b 3602p asking for PIN for settings menu
    What am I missing?
    Reset/ Clear Security Setting
    How To
    Related Products:bizhub 4702P,bizhub 3602P,bizhub 3622,bizhub 4402P,bizhub 4422
    Related Options:
    Question
    How to reset or Clear the security setting on the device?
    Answer
    There are two options to use to clear your security settings.
    Option #1: MFP: Enter the CONFIGURATION menu from the device's operator panel.Note: For security to be cleared you MUST select the options listed above.
    1. Power OFF the device.
    2. Remove plastic side cover then remove the metal side panel to access system board.
    3. Pull jumper and move from pins 1-2 onto pins 2-3 or vice versa. Close panel.
    4. Power ON the device, security should be cleared to factory defaults.
    OverviewBenefits
    Provides a two-way method to recover a device if a local password is lost or forgotten, or if the device loses its ability to communicate with the network.
    DetailsCAUTION:
    • igor.sanfilip
      • Mar 2015
      • 11
      Jumpers worked!
      Thanks.
